Hardtop headlining replacement
Quaser
Post Wed Dec 12, 2012 10:22 pm
Hiya
Can anyone recommend someone to redo the headlining on my hardtop - im thinking of getting this:
http://www.ebay.co.uk/itm/280581001385? ... 1423.l2649
Will it be ok to have it stuck straight on the roof or will it need a spongy backing?
Q
faze30
Post Fri Dec 14, 2012 9:28 am
hi mate.
Re-lining a hardtop isnt easy as it looks. As mine needs doing. I spoke to 3 upholstry guys and they all quoted me £450 minimum as all the rubbers are all glued and the window needs to come out. not an easy job
im waiting for the summer to get mine done
mk3-ralf
Post Fri Dec 14, 2012 11:02 am
there are a couple of guides floating around on the net...and it didn't look too hard..from what i remember the rear screen didn't need to be taken out but blunt knife / spatula was used to tuck the material in....at £450 i would attempt it myself before taking it to a retrimmer. At least you would have already taken it apart so could knock a bit off the price
gooner1
Out humping Reindeer
Post Fri Dec 14, 2012 11:30 am
http://forums.bimmerforums.com/forum/sh ... p?t=642751
I take no responsibility for any cock ups that may occur whilst following the above procedure. :)
mk3-ralf
Post Fri Dec 14, 2012 11:42 am
http://www.r3vlimited.com/board/showthread.php?t=179607
heres a quick fix guide if you want a temporary fix
faze30
Post Sat Dec 15, 2012 8:48 am
When i first got my hardtop it was sagging a little. I undone the roof lining which was sagging. Took away the foam which was all perished. Cleaned it up and used spray glue to tuck it all back, was good for a week. Then started to sag again. So i may just get it professionally done in summer.
I know its a rip of.
But what if we do a group purchase, maybe get it a little cheaper if more than 1 person gets theres done??
faze30
Post Sun Dec 16, 2012 7:55 pm
I used fabric spray glue. Didnt really work well.
Z3I
Post Sun Dec 16, 2012 9:04 pm
faze30 wrote:I used fabric spray glue. Didnt really work well.
Spray glue does work, but the remains of the foam which has disintegrated needs to be cleaned well away first. If you spray it on the remains of the old glue, it will pull away again. I've seen the results in Germany, and its good.
I'm currently looking for someone who will undertake this work on the basis of : Remove original healining, clean off original foam, fit new foam backed headlining without removing rear window and seals. Target is £200 or under!
Z3I
Post Sun Dec 16, 2012 9:05 pm
diable wrote:I think something like this would be better
http://www.ebay.co.uk/itm/2-x-500ml-Pro ... %26ps%3D54
Thats the stuff...
emmaitch
Post Mon Dec 17, 2012 9:40 am
I need the same job doing too
