alarm advice
318isPMK
Post Tue Dec 11, 2012 10:00 pm
Hello guys.
Tried to start my car and it's taken a wee bit longer to fire... just a second or so but enough to make me think that's not right.
And now my alarm has went off 5 times this evening is it likely the two are connected is my battery dying?
I know this is cheeky but it's my Lexus not the e30.
Post Tue Dec 11, 2012 10:05 pm
Which Toyota have you got ? :)
318isPMK
Post Tue Dec 11, 2012 10:16 pm
Is200s
Curr946
Post Tue Dec 11, 2012 11:06 pm
with the cold weather were getting I would put a bet on that its your battery
If your wife must learn to drive, don't stand in her way!
Post Tue Dec 11, 2012 11:07 pm
Battery - either dying or not charging properly.
318isPMK
thank you very much
bhaza
Post Wed Dec 12, 2012 6:30 pm
Yeah if it's a After market alarm usually they will trigger off if car battery is low, so really could also be alternator not charging battery. Best thing is to get the battery tested and see if alternator is charging battery.
Halfords, kiwi fit, independent garage all should do these test free of charge mate.
Hope this helps
318isPMK
Post Wed Dec 12, 2012 6:42 pm
It's a'll standard OE
polsta
Post Wed Dec 12, 2012 7:06 pm
318isPMK wrote:It's a'll standard OE
how do you know ? have you removed it all/looked at the unit etc ?
318isPMK
Post Wed Dec 12, 2012 7:11 pm
It's standard Lexus key fob alarm stuff. No reason to suspect it's aftermarket.
I've bought a new battery today so will see how it goes if it's popped in.
