Squeeky wheel
318isPMK
Post Sun Dec 09, 2012 5:26 pm
Can this be fixed or do i need a replacement part.
I have lubed the copper/brass ring and I have fitted the blue tac :) it seems to go for a few hours and come back again.
318isPMK
Post Mon Dec 10, 2012 3:40 pm
Bump
any advice?
Post Mon Dec 10, 2012 3:44 pm
hammer time !
that would bug the shoite right of me .
new copper ring ?
Post Mon Dec 10, 2012 3:53 pm
Check the steering UJ under the bonnet first, as if it's squeaking, this will be transmitted up the steering column.
318isPMK
Post Mon Dec 10, 2012 4:05 pm
Engine problem diagnosed as faulty carburetor 120 to fix not bad.
What's a UJ?
I'll have a scout around for the ring I wasn't sure if u could buy them.
Post Mon Dec 10, 2012 4:45 pm
the uj's are this bit that comes out of the bulkhead beneath the battery and go to the steering rack,spray all the knuckle joints with wd40 and see if goes away ?
http://www.ebay.co.uk/itm/170956771789? ... 1558.l2649
318isPMK
Post Mon Dec 10, 2012 4:51 pm
Cheers magpie
Das_BMW_E30
Post Mon Dec 10, 2012 5:05 pm
Sounds like the bottom bearing on the steering column, simple fix, remove lower panel, measure up 150mm from bottom of column tube, drill into the side of the column tube with 5mm drill bit, pump in some 3in1 oil, job done....
Post Mon Dec 10, 2012 5:19 pm
Doesn't that method risk getting swarf inside the column tube? :eek:
Das_BMW_E30
Post Mon Dec 10, 2012 5:42 pm
Drill with a new drill bit, at an even speed and watch in amasement as the metal just "spirals" outwards....
Tried and tested the above, and can confirm it works...
318isPMK
Post Mon Dec 10, 2012 5:59 pm
What's swarf?
Post Mon Dec 10, 2012 6:07 pm
the waste metal .
318isPMK
Post Mon Dec 10, 2012 6:10 pm
Thought that. Can you get a magnetised bit.
Also it sounds drastic is that a recognised fix? Think I'll go with the wd40 and new copper ring if thats possible. I had the same issue with the Is bought a new wheel and that sorted it but don't want to shell out unless I have to.
318isPMK
Post Mon Dec 10, 2012 6:16 pm
Das_BMW_E30
Post Mon Dec 10, 2012 6:21 pm
You need to get oil to the lower bearing on the column..spraying WD40 upwards is no good, it will not penetrate, and gravity will see it drip off.
I suffered for ages with a really harsh and squeeky lower bearing, I looked around the web, and came across the above method.
Drilling a small hole in the side of the column six inches up, allows you to insert a 3in1 oil can tip, and put some oil in, it flows down the inside of the tube, and coats the bearing, job done...
Das_BMW_E30
Post Mon Dec 10, 2012 6:34 pm
There's a short thread here, about an e36..
http://www.bimmerforums.co.uk/forum/f17 ... fix-t8378/
I think 75mm up is not enough on an E30, mine was more like 150mm up from the bottom of the column.
It's best to drill in from the side, and allows easy application of the oil into the column.
Post Mon Dec 10, 2012 6:37 pm
magpie wrote:the waste metal .
I am going to resist temptation :)
craigieeb
Post Mon Dec 10, 2012 11:17 pm
:chuckle:
