Engine loom removal - ECU plug
hennared323i
Post Sun Dec 09, 2012 3:59 pm
How in the name of all things religious are you supposed to get the ECU plug through the grommet in the bulkhead?
I'm currently contemplating Vas and brute force :x
maxfield
Post Sun Dec 09, 2012 4:14 pm
It does fit just have to fiddle.
TPS
Post Sun Dec 09, 2012 4:16 pm
I've done 2 of these, you have to push it from the Battery tray end, I resorted to using a Bladed screwdriver, I think.
hennared323i
Post Sun Dec 09, 2012 4:18 pm
TPS wrote:I done 2 of these, you have to push it from the Battery tray end, I resorted to using a Blades screwdriver, I think
I am taking it out.
I guess it is contortionist time to force it out from inside the car
Post Sun Dec 09, 2012 6:30 pm
ECU plug through the grommet? Or ECU plug through the bulkhead hole the grommet sits in?
maggspower
Turbo Farmer Tractor Driver
Post Sun Dec 09, 2012 8:58 pm
DanThe wrote:ECU plug through the grommet? Or ECU plug through the bulkhead hole the grommet sits in?
Hmmm, good point :D The first one would be like trying to sh1t a pineapple.
The grommet should come out with the loom.
hennared323i
Post Mon Dec 10, 2012 11:11 am
Grommet out it is.
Ta muchly
