Alpina B10 Bi turbo, this car is haunting me 11/2/15
Post Sat Dec 08, 2012 11:12 pm
Well if its a crack getting it welded up won't be a problem. Getting it all off might be another. A phone call to usual experts might be order
Post Sat Dec 08, 2012 11:29 pm
Its not the rear manifold, its coming from the front turbo area but that is shrouded with heat shields and not very visible.
Forgot to say earlier, a lot more room than an E9x 335i!
Sorry about the clutch Si!
Post Sat Dec 08, 2012 11:33 pm
Poor Barry the beast broke me motor! :o
Its ok it will do some big no. 11's now up santa pod next year in the knuckledragger faceoff, and i can break something else i expect
Post Sat Dec 08, 2012 11:38 pm
A battle plan has been forged for the work, Si just needs to lay some bricks to pay for the "Alpina tax" parts. :eek:
Post Sat Dec 08, 2012 11:41 pm
Impressive :cool:
Jon_Bmw
Dangerous when thinking
Post Sun Dec 09, 2012 9:04 am
Nice power! As I'm uneducated, what did they produce from the factory?
I agree that it probably is an exhaust leak throwing the afr readings. At a real 15:1 you'd be melting pistons pretty rapidly! It looks like the exhaust has had a couple of repairs as the pipe looks a slightly different size by one of the boxes. Not suprising given the cost of replacement Alpina exhausts!
Imagine this and a lotus Carlton giving it hell for leather in 1994. What a pair of heros they woud have looked whilst everyone else is all excited about the new Astra gsi. :eek:
Post Sun Dec 09, 2012 9:31 am
Alpina quote 360bhp and 385lbs on full boost and 300bhp on minimum. I think from what i've read they are a touch conservative figures for an uptogether healthy bi turbo.
The rear box is a bit sad but its £2500 new :eek: i thought it shared this with the NA B10 but a second look reveals it doesn't its bi turbo only, yikes
**BANNED**
Post Sun Dec 09, 2012 10:35 am
Custom made s/s box?
Nice power run fiqures,BTW :D
Post Sun Dec 09, 2012 11:32 am
i'd rather repair whats there we will have to see
Post Sun Dec 09, 2012 12:09 pm
e30topless wrote:Si, the blow will probably be on the rear manifold, the Bi is well known for going there, IIRC it's not a cheap fix but worthwhile doing, interesting to see they use a MAF ?
nice to see she's making good power :D
Birds have done all the manifold studs and gaskets fairly recently, the bill was epic ! :eek:
PS Clutch kit = Alpina only, approx £900 + vat :(
Post Sun Dec 09, 2012 1:31 pm
Perhaps that's why the previous owner sold it, knowing that the clutch was on its way out...
Rosc0PColtrane
Post Sun Dec 09, 2012 1:52 pm
pony wrote:
Rosc0PColtrane wrote:
pony wrote:I think a 520 or 525 badge would suit well as shows has 6 cylinders but is a base model
Looks good :-)
That is so gay.
Explain ?
It really doesn't need explaining.
Speedtouch wrote:Perhaps that's why the previous owner sold it, knowing that the clutch was on its way out...
If you could see the bills the previous owner had been served with in his tenure, you would know that a 2k clutch job would barely be noticed.
When we went through the incredibly detailed history, it was noted that it did not appear to have ever had a clutch :(
Post Sun Dec 09, 2012 3:00 pm
What is the grand total around about Pete, more than the original purchase price?
Morat
Post Sun Dec 09, 2012 3:53 pm
OUCH!
but what an epic motor :) I bet the Renault Clio Pilots looked a bit sheepish when they saw your printout!
Andyboy
Alpina Colada
Post Sun Dec 09, 2012 4:06 pm
Check out the maintenance bills on a 1993 Testarossa. A BiCurious will be a pittance by comparison.
Post Sun Dec 09, 2012 4:35 pm
they're as fast as one of those so i hear with 4 seats and a big boot!
Andyboy
Alpina Colada
Post Sun Dec 09, 2012 6:54 pm
Simon13 wrote:they're as fast as one of those so i hear with 4 seats and a big boot!
Yep, that was the whole point - supercar peformance in an E34.
Lots of regular bits on these as well - the cam is standard 535i, 8 Series prop coupling, 750i front pads etc etc.
winx
Post Sun Dec 09, 2012 6:55 pm
An enjoyable day, Clio weirdos were actually quite knowledgeable about the beast...
Forgot to say Pete - Charlie asked me to call you something nasty, I will on Thursday
:P
Post Sun Dec 09, 2012 10:57 pm
The previous owner paid 14,750 for this in 2003, munich bellends were involved in some way. He didn't like them hence using other garages for upkeep.
He spent on the upkeep of this car £17,795.45 8O No skin flinting here! I can save on labour but not alpina parts prices, its worth it with this car
suchy
True Zone Relic
Post Mon Dec 10, 2012 8:56 am
I'm a bit behind with Zone news so have only just read this thread. What a magnificent chariot 8)
Post Mon Dec 10, 2012 6:02 pm
:clin: Went to the dealer, wait for it!
454 + vat for pressure plate
289 + vat for friction disc
54 + vat for release bearing
total
£956.40 all in for the lot and a 5-6 week lead time for delivery, my dealer will give me 10% discount as there is only a 20% margin.
860 ouch,
Anyhow a chap gave a link to this performance sach clutch for bi turbos for alot less
568 euros, i guess meatballs could help a little also?!
says it can transmit 480Nm+ of torque, the car did 550Nm on the dyno on saturday. So will it be up to it?!
heres the link
http://www.sachsperformance.com/Sachs-P ... _1512.html
I found a part no. for the turbo gaskets, its now NLA. But surely they're generic for T25s as the turbo flanges are same for all the T25's applications ya?
TBH i need to get the heat sheilds off and then try to see exactly where the blow is coming from before spending monies.
Theres a small oil leak from a pipe below the turbos entering the block above the sump. Along with the diff leak. Birds have done both these leaks in the last 2-3 years ican see.
A pinion oil seal shouldn't leak again that quickly no? Its quite bad but theres probably about 5 litres of oil in total for the diff with all the pipework for the cooler fitted to it.
pony
Post Mon Dec 10, 2012 6:14 pm
I don't think will be up for it as cannot take all the torque unless u are prepared to poorly abouy
Post Mon Dec 10, 2012 6:21 pm
eh?
**BANNED**
Post Mon Dec 10, 2012 6:38 pm
Clutch wear will be dependent more on the amount of slippage whilst using 'launch control',as opposed to full throttle turbo use with the clutch fully engaged.
So if you can control the 'boy racer' in you,that Saches item should be up to the job.
Just one aspect of running a champagne motor on beer money,I guess!
Meatballs is a good guy,I am sure that if he can save you cash,he will do. :D
Youth is wasted on the young.
Jon_Bmw
Post Mon Dec 10, 2012 9:53 pm
Did you get the BMW part numbers Simon.
Post them here if you have them and someone might be able to cross them to see who was the manufacturer to go direct?
pony
Post Mon Dec 10, 2012 10:12 pm
I meant the clutch cannot take maximum torque so you will have to adapt your driving style so you do not use max torque which is no fun. For a few extra hundred quid just shell it out and get the proper part what's the point in doing otherwise
Post Mon Dec 10, 2012 10:16 pm
ZF/Sachs are c00nts for discounting, I have a mate that works in design for them and even he cannot get anything off retail
Post Mon Dec 10, 2012 10:28 pm
it slipped in 5th gear on motorway when putting pedal down. Yes it was on max boost. Makes me like it even more, that takes some doing imo.
Pacers been down this route but anyhow
pressure plate 91 47 21 20 622
friction disc 91 47 21 20 623
release bearing 21 51 12 23 366 - this is fitted to a whole load of old skool stuff e9's e12's etc
Post Mon Dec 10, 2012 10:30 pm
DanThe wrote:ZF/Sachs are c00nts for discounting, I have a mate that works in design for them and even he cannot get anything off retail
This. Both Biturbos that I have owned have needed clutches. I tried everything to save shekels but to no avail. At the time , even going in the back door at Sachs worked out no cheaper than BMW :(
I have seen tight wads use 535 and M5 clutch components but 400lbs of torque means that always ends badly and the job needs to be done again. It is definately not a job anybody would want to do twice in a hurry :(
The macau Biturbo I had was allegedly fitted with a Sachs 'racing'sourced clutch and it was dead within 5000km, conveniently just outside the one year warranty window. The replacement clutch was bought from BMW :cry:
Post Mon Dec 10, 2012 10:35 pm
Main dealer isn't it. lots of bricks to lay. :( :o
pony
Post Mon Dec 10, 2012 10:38 pm
So is your clutch completely broken or just slipping ?
Presumably when it happened was well on its way out.
Think of it as like getting a new set of tyres all round ....
Post Mon Dec 10, 2012 10:40 pm
Well, you wont have to do it again if you buy a proper one
Post Mon Dec 10, 2012 10:41 pm
Its fine for now, just no giving it death on full boost. It will take a long while to die completely
Sonni it won't of died come thursday night don't worry!
Post Mon Dec 10, 2012 10:42 pm
I expect it will still toast a 46 turd with a slipping clutch and half boost :D
