touring rear springs/shocks upgrade heavier load help needed
jonny323i
Post Sat Dec 08, 2012 9:37 pm
I need to upgrade my rear suspension in the touring to help carrying all my tools has anyone got any suggestions.
Iv found out today that bmw actually do springs to be fitted when you use the detachable towbar so i pressume they are heavier duty but by how much i dont know.
From looking on real oem there is also different size pads for under the springs can these be used with any spring to give a little more ride height.
Also is there an ugraded shock i can fit along with any springs i use to help with the load.
Any ideas on where to source the relevant parts too would be great
Touring for life
Post Sat Dec 08, 2012 9:44 pm
Why don't you fit Spring pads John.
jonny323i
Post Sat Dec 08, 2012 9:51 pm
please elaborate rav iv not looked into anything like this before so im not sure what my options are....
ps your looking good on the halfords ad did they pay much
Touring for life
Post Sat Dec 08, 2012 9:54 pm
LOL, not Halfrauds stuff.
It's a heavy duty foam pad that goes into the spring coils, acts like a bump stop
jonny323i
Post Sat Dec 08, 2012 9:59 pm
oh you mean spring assistors iv got them fitted already and they do help but i really think i need more. They are coiled and slide in between the rings of the coil.
I wondered if i could use coil overs at the same time as springs but i pressumed they will only be set at a lowered height
Touring for life
Post Sat Dec 08, 2012 10:05 pm
You can get stiffer springs from Faulkener Springs
http://www.dfaulknersprings.com/
jonny323i
Post Sat Dec 08, 2012 10:18 pm
iv emailed them so i will see what they come up with thanks
Touring for life
