Track/fast road 2013 built and tracked
Update****
Dug it out my garage expecting rust and to strip the cage seats ect and scrap it and get a clio 182 for some track abuse........ its still solid
so after a few seconds of decision making the cash stays in the bank and the 30 stays.. sooo works begun to get some track days done in it this year
Last time I had it on the track it suffered in afew areas. So im getting all the week areas sorted and im going to have some fun in her.
Old front (always hated yellow lamps)
New front
New susp
Picked a 3.91 lsd up have been fighting with it to get the drain plugs out and changed the oil and while I was at it have thrown on some hammerite ill put another coat on in the morning
-not a show finish but its not a show car.
Given the bay a tidy
As it stands
Thats it for a days work,
Ive orderd a ashley competition race exhaust, electric fan, new (second hand) wheels,
Im pulling the interior out tomorrow to send the cage of for powder coating and refresh the inside and cut some wireing out to save some more wieght.
New front
New susp
As it stands
steve_k
- Contact:
looking good dude, will have to keep an eye out for it next time i'm over derby way
This mornings work:
Gave the diff another coat of paint, removed my cage and seats
Got another bonnet for it, fitting aero pins to get rid of that heavy mechanism at the front
Im struggleing to get the front piece out- need to remove the dash
While the dash is out im going to find a replacement thats not got cracks in and get it flocked, also im not sure if im going to refit the front half of the cage... it wieghs a ton!
Interior metal work colour... ideas on a postcard black, white or orange like the cage? Im repainting it but fancy it alittle brighter in there, bearing in mind it will have orange cage and the car maybe going orange or white on the outside...
- E30 Zone Meets/Events Team
- Contact:
Yes, get yourself a "Swearbox" ready.Nato_e30 wrote:Looks like the rear subframes coming off this weekend for camber plates and poly bushesany tips for removal?
Busy day today... spent the morning serching for parcel depos for beemer parcels! Then this afto set about removingthe rear subframe, diff ect.
The beginning. .
Scorpion removed.... heading for ebay.
Ooooh already poly bushed cheers telski
Next up srip the beam, weld on rear camber plates, powder coat, and rebuild with uprated arb and new oem drop links, underseal the underside of the car, referb calipers, replace fuel lines and brake lines and wheel bearings (saves any hassel for a while and means i hopefully can have some trouble free track days. its a bonus its already got braded lines and poly bushes
And I now have one v pissed of wife... oooh nooo!
The beginning. .
steve_k
- Contact:
looks good, did you find out about the manifold?Nato_e30 wrote:Ashley arived.. not a single pipe system like I wanted :/ non the less very pleased and v light
h removed and stripped
Remainder of the cage removed
Cluster before mod,
After mod, white dials and the irritating mpg needle removed
Afew parts have arived,
Drop link, rear swing arm, and axel carrier poly bushes are here
Next up,
Paint the inside
Drop all removed parts to media blast inc cage
Then drop blasted parts to powder coating
Drop the dash, center consol and steering wheel at preys for flocking
Cluster before mod,
Next up,
Paint the inside
