Fuel pump fitting
imye30
BMW e30'convertible fuel pump fitting guide is or hard what needed
No different from a saloon. Remove rear seat, remove RH access cover, remove level sender, remove pump, reverse sequence with new pump.
- **BANNED**
Make sure you re-connect the leads the correct way round.....
Youth is wasted on the young.
