no windows and no heaters
hass
Fri Dec 16, 2005 10:12 pm
hello everyone i have a problem with my e30.my electric windows arnt working with the ignition on or when running the only time thay work is when the door is open.also i have no heaters the heater motor isnt working.
i check all fuses when i live the fuses for each part thay work.
i swapped relays over,still the same.
i wonder if theres somthing im missing out on.
if you know or have any ideas plz reply.
thanks for looking HASS
alan325i
Sat Dec 17, 2005 9:22 am
i had this problem with mine earlier this yr.
Fault was a corroded earth, mine was located under the top cover of glove box. had about 5 earth wires there, cleaned them with wire wool
Sat Dec 17, 2005 11:22 am
Both your unloader relays (K5 and 7) aren't working. Mirrors shouldn't be working either.
See "unloader relays and starter trigger thread".
16azev_needed_for_my_e30
Sat Dec 17, 2005 11:39 am
Just posting so i can keep track of this thread as my mirrors & drivers window are playin up
hass
Sat Dec 17, 2005 4:36 pm
just to let evry1 know it was my starter wire the top one was corroded!!
thanxs for evry1 who repleied to my problem.
thanxs :D :D :D
