Strutt braces (are they worth it?)
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Thu Dec 15, 2005 10:11 pm
Thinking of getting a strut brace for my cab. Firstly are they a good way to spend >Ԛ£100 and if so what should I go for? Andrew (Demlotcrew) suggested a double sparco to me ages ago, just wondered if that was the general concensus or if other people have other ideas?
thanks
:thumb:
kam-325i
Post Thu Dec 15, 2005 10:16 pm
They can tighten the front end up on cornering, But i dont know about the cab's because the lack of a roof. Where does the stress go ?
NIX
Post Thu Dec 15, 2005 10:25 pm
Hi mate,
I've got a twin tubed sparco strut brace, and to be honest with you, due to the fact that my car has a few handling issues at the moment I haven't really been able to notice a huge difference and haven't really ragged it round bends too much. Waiting to get a few bits and pieces sorted first. But will say that in the mean time it has atleast made the engine bay look tastier. I'm sure it has stiffened the car up somewhat and is worth Ԛ£100, but beware, as mine can be a bit of a bitch to put on and take off as its not aligned for a snug fit between the turrets - bit tight. Just means a bit more swearing when working around it or changing the suspension.
kam-325i
Post Thu Dec 15, 2005 10:26 pm
The tightness of the fit can be caused by the turrets "sagging" over time.
orangecurry
Post Thu Dec 15, 2005 10:31 pm
in other peoples opinions that I've read, no not worth it... doubly-so not worth it with a cab, because you already have strengthening sections welded on both sides of your front turrets... the strut brace will add very very little
however, I'm sure someone will disagree; that's the great thing about the 'zone :D
NIX
Kam-325i
That would make sence since I had to have some welding done below the turrets due to rust/holes of which would have reduced the stiffness before I got it sorted.
Post Thu Dec 15, 2005 10:36 pm
a strut brace on it's own does not make a massive difference, but when u add it to a car which has all the other good suspension parts on it, it fine tunes it even more, if u get me.
Like a 6 branch manifold will help alot more a tuned 6 pot engine, than a standard engine with the 6 branch fitted on it's own
NIX
orangecurry wrote:in other peoples opinions that I've read, no not worth it... doubly-so not worth it with a cab, because you already have strengthening sections welded on both sides of your front turrets... the strut brace will add very very little
Even though I've got a twin tubed brace, I do think it is a bit uneccessary, single would have done fine. But its not a great deal more expensive than a single brace and looks meaty...ggrrrr!
orangecurry
Post Thu Dec 15, 2005 10:37 pm
here's a picture I took of my cab turret for another thread!
note the triangle-ish plate welded on the outer-side and the long box-section welded on the inner-side of the turret running down to the chassis - these are not present on non-cabs
William
Post Thu Dec 15, 2005 10:43 pm
Simon13 wrote:a strut brace on it's own does not make a massive difference, but when u add it to a car which has all the other good suspension parts on it, it fine tunes it even more, if u get me.
I see, I guess standard Mtech suspension probably doesn't fall into this bracket, whereas maybe an H&R Cup kit might?
orange, I didnt realise those bits were not present in non-cabs, there are so many differences all over the car in pretty much every aspect, shows how much of a 'designed' cab the e30 was for its time, rather than just an after thought of chopping the roof off!
:thumb:
zaust
Zone day release
Post Thu Dec 15, 2005 11:05 pm
orangecurry wrote:here's a picture I took of my cab turret for another thread!
looks like you had a big whack m8..
strut braces are to stop over flexing under extreem conditions ie trak use.
which in turn will cause under or over steer depending on corner/drift.
M30 Tech 1 Touring on gas.
Demlotcrew
Post Thu Dec 15, 2005 11:20 pm
zaust wrote: looks like you had a big whack m8..
What makes you say that?
Andrew
zaust
Zone day release
Post Thu Dec 15, 2005 11:29 pm
Thats how i made mine stronger after replacing the wing, flitch and having
had a jig. still got ripples too..
ian332isport
Post Fri Dec 16, 2005 12:08 am
orangecurry wrote:the long box-section welded on the inner-side of the turret running down to the chassis - these are not present on non-cabs
Yes they are :D
Here's a picture of the one on my Sport.
Ian.
Post Fri Dec 16, 2005 12:14 am
Ian is that your flintstones E30? wheres Barny?
ian332isport
Post Fri Dec 16, 2005 12:17 am
Simon13 wrote:Ian is that your flintstones E30? wheres Barny?
:lol:
herman
Post Fri Dec 16, 2005 12:25 am
Did'nt have them on my last M3, got them front (twin) and back on Herman M3, do make a difference. I think single are just as good.
Chaos
Post Fri Dec 16, 2005 12:31 am
not quite.
i used to know a guy who was a suspension engineer for Ford r&d.
he stated that a strut brace "should" do nothing, but in reality simply allows the suspension to do what its desinged to do.
the problems occur due to the production cars not being as torsionally stiff as the prototypes where the suspension is developed - in this instance adding a strut brace then helps to bring everything back to how it should be.
Chaos
causing havoc and mayhem wherever i go
nikos
Post Fri Dec 16, 2005 12:48 am
on the cab you will see a huge difference if you use the cross brace to the bridge, see mine
1991 325 cabio t/c 3.2 evo, 6speed, e36m3 rack, adj bilstein,
http://s241.photobucket.com/albums/ff262/granitsas/
orangecurry
Post Fri Dec 16, 2005 5:48 pm
no whacks of any kind - I've had 2 cabs and the factory-welding was identical
I haven't seen these extras on any other E30, and was told they never were - obviously that is wrong... are they on every Sport as well?
ian332isport
Post Fri Dec 16, 2005 7:22 pm
As far as I'm aware, all E30's have the brace running up the long side of the strut tower. You are correct about the ones that go from the strut tower to the inner wing though. This was a cabrio specific thing.
Ian.
orangecurry
Post Fri Dec 16, 2005 11:36 pm
strange... I must be going mad.... again
anyway, cabs also have an extra wodge of metal behind the dash from one side of the car to the other - see MrLees pictures on another thread
that'll be doing as good a job as any strut brace
nikos
Post Sat Dec 17, 2005 2:07 am
yes, but you forget they are cabs
orangecurry
Post Sat Dec 17, 2005 8:08 am
nikos wrote:yes, but you forget they are cabs
in what way? If there is already extra stengthening at the front, a strut brace can't really make much difference if any; if something is braced, it's braced.
what WOULD make a difference on a cab is, say, oooh I don't know... something higher up... that ran somehow overhead.. say...erm... a roof
mrLEE30
Post Sat Dec 17, 2005 9:07 am
here you go, will save you the searching!
reckon in a cab the difference will be mainly imaginary, plenty of bracing there, but then again why are they on race/rally cars?? personallly the 100 quid would be better spent on a new set of shock absorbers or bushes, that would improve the car
nikos
Post Sat Dec 17, 2005 11:01 am
then why bmw used the cross brace for the later cabrio? and why is a standart bmw item?
Demlotcrew
Post Sat Dec 17, 2005 11:22 am
nikos wrote:then why bmw used the cross brace for the later cabrio? and why is a standart bmw item?
What cross brace?
Andrew
Demlotcrew
Post Sat Dec 17, 2005 11:24 am
zaust wrote:Thats how i made mine stronger after replacing the wing, flitch and having
Ha ha, thats not welds! its pannel sealent many E30's have the same!
Andrew
d6dph
Post Sat Dec 17, 2005 1:24 pm
well having just got back from a good (if a little slippery) thrash around the backroads of colchester. i can say my car feels a lot better for having a brace fitted.
the car is sound, no rust or knackered bushes, and its made it loads nicer to push hard. worth the bucks i'd say
stevetigger
Post Sat Dec 17, 2005 2:51 pm
mrLEE30 wrote:here you go, will save you the searching!
Normal E30's have that!
mrLEE30
Post Sat Dec 17, 2005 3:44 pm
cabs must just be thicker, i know that cause i tried putting a coupe dash in a cab and it wouldn't fit (four fckin hours of pi55in about) then i had to cut about two inches off each end.
Chaos
Post Sat Dec 17, 2005 4:49 pm
mrLEE30 wrote:cabs must just be thicker, i know that cause i tried putting a coupe dash in a cab and it wouldn't fit (four fckin hours of pi55in about) then i had to cut about two inches off each end.
the windscreens are the same.
Chaos
Cotty
Hartge Crew
Post Sat Dec 17, 2005 10:45 pm
Well I dont care if it does anything or not but the one I bought from the Zone Shop is going on anyway.
Suspension is being done at the same time so not sure if I wil be able to see a difference as it not bing changed on its own
M5pilot
Post Sun Dec 18, 2005 10:05 am
Strut braces make a difference. There are lots of people who have tried them and come back saying they feel the front to ride better and turn in alot better.
stevetigger
Post Sun Dec 18, 2005 9:23 pm
M5pilot wrote:Strut braces make a difference. There are lots of people who have tried them and come back saying they feel the front to ride better and turn in alot better.
But what about on a convertible?
