Dbilas Dynamic multi throttle body intake system
JazzMan
Post Fri Dec 16, 2005 4:00 pm
http://www.dbilas-dynamic.de/dbilas_eng/index.htm
Has anyone used this intake on an M20B25, what sort of power gains can be expect? Does it require an ECU remap or would a Zone chip suffice to start with?
It certainly look snazzy!
Dan320is
Post Fri Dec 16, 2005 4:04 pm
Player6 (Scott) has recently had this system fitted to his car, although his is a 2.7/2.8 he might to be able to tell you what is involved and what sort of power increase you can expect.
PM him.
buster
Post Fri Dec 16, 2005 4:06 pm
Dale had one on his 2.5 m20 also
Ant
Retired Team Member
Retired Team Member
Post Fri Dec 16, 2005 4:14 pm
you'd be mad to fit those and not use a standalone, the AFM sitting on the far end of the plenum will do nothing but restrict the performamce dudes.
use those with MBE/Alpha N/Emerald, MS etc etc , whatever you choose alpha N mapping is the only way forward
Scotts car flies !, but how much is down to the Tbs..... hmmm I'm over there, on the fence :lol:
player6
Post Fri Dec 16, 2005 6:43 pm
scot 328i with 260bhp
M5pilot
Post Fri Dec 16, 2005 10:45 pm
As Ant says, no point without stand alone management.
Also, you really need a lairy engine like Scots to take the full advnatge of them. No point unless you have a cam.
The power delivery will drastically change aswell, it will become much more linear and lose that big peaky torque the 325i has.
Not worth it if you have a standardish engine, stick to your standard inlet manifold which isnt a bad design.
Jordan
Post Sat Dec 17, 2005 12:34 am
I would absolutely love one of those for my 2.8 m20. But alas... they are way too expensive.
JazzMan
Post Sat Dec 17, 2005 12:47 am
Thanks for all the input :D Maybe something for a later day once I've got the car running for a while. I plan to a use a custom ECU at some point, just not yet. For now I will stick to BBTB, chip and custom exhaust - adding a cam later once I have time to service the engine properly :)
Andy335Touring
Post Sat Dec 17, 2005 12:48 am
How far off are you from finishing it ?
JazzMan
Post Sat Dec 17, 2005 12:52 am
Andy335Touring wrote:How far off are you from finishing it ?
I'm aiming for this summer, its slow going at the moment as the garage is freezing!
