Gem's E30 325D Touring
GemE30
GemE30
oomz1975
GemE30
59Drifty
glad to hear this gemma!
redcar
Really nice!
GemE30
e301988325i
Lots of skills used here, impressive to have got it all working.
Having had a couple of M51's,it would be wise on the injector return pipes to create a loop from injector 1 and 6 back to tank, I used a washer hose T piece for this. otherwise the cap on injector 6 gets cooked over time and leaks diesel everywhere.
Secondly the 3.0L E36 M3 rack is a dud, is variable ratio and super super slow in the straight ahead position, the 3.2L is the same as other E36's but has lock limiting spacers on the ends on the rack inside the boots which should be removed.
I said:
e30topless said:
lock the wife in there
GemE30
Thanks for the advice.
crossie
What mods have you made to the engine on this as I have a e36 tds as a daily driver and it currently return on 28mpg - I know the egr has been removed anything else altered?
have you had it remapped?
e301988325i
Something is quite wrong, are all the boost pipes near the EGR is good condition, has the air filter been changed ever?crossie wrote:What mods have you made to the engine on this as I have a e36 tds as a daily driver and it currently return on 28mpg - I know the egr has been removed anything else altered?
I said:
GemE30
GemE30
crossie
air filter changed a couple of months ago!e301988325i wrote:Something is quite wrong, are all the boost pipes near the EGR is good condition, has the air filter been changed ever?crossie wrote:What mods have you made to the engine on this as I have a e36 tds as a daily driver and it currently return on 28mpg - I know the egr has been removed anything else altered?
havent really looked at the pipe work!
it all seems fine!
may test them with soapy water next weekend!
GemE30
crossie
inlet track & the mechanical pump - what did you clean these out with?GemE30 wrote:Crossie - This hasn't been remapped as we do not run an ECU so cannot be done. All we have done is fully remove the EGR, cleaned out all the inlet track & the mechanical pump, we also turned the wastegate actuator in and turned the fueling up and are currently getting near on 42mpg.
how did you turn the fueling up?
steve_k
the more i see this car the more i think about doing this conversion
had a look on ebay & found a few m51 engines on there for about £300, & knowing someone who is a dab hand at rebuilding them is making it even more tempting to do.
loving the car gem it just gets better.
if you don't mind m asking, where did you get the braided hoses from & end peices/conectors for the catch tank from?
also, what would be involved in the whole conversion??
kepp having dirty thoughts about tech 2 sport on keskin kt1's with a big old force fed oil burner up front (heavily tweeked of course
GemE30
We got the hoses from East Midlands Hydraulics in Ilkeston.
The whole conversion is a ballache.
steve_k
thanks for that gemGemE30 wrote:We got the hoses from East Midlands Hydraulics in Ilkeston.
it might be a ballache but if the end results look as good as your's then it's worth it lol.
GemE30
In all honesty dude, it really is. Sump's are one of the main issues we are having trouble finding.
mrrodney
gem what gear box did you use??
GemE30
Standard e30 one.
redcar
Sorry if you've already mentioned it somewhere, but how many bhp and torques are you expecting?
How much do they have as standard?
GemE30
I don't know tbh. We're yet to get it rolling roaded which is something I'm aiming for early next year
59Drifty
when you go for a RR ill have to come along too
GemE30
craggsyE30
haha ^^^^ that would be the other way round for me
GemE30
It usually is for me
craggsyE30
very nice car though saw ti at pod this year
GemE30
Coops90
Bugger!
At least you have an excuse to put standard back lights on now...
Malachite uber alles
craggsyE30
thats sucks being where the repair is you could blend it just using the quarter keeping it to the top of the tailgate
GemE30
I liked my lights
