is this a torsen diff?
BMW_E30vert
Post Tue Nov 27, 2012 10:28 pm
bought this diff which came off a 2.8 z3 1998, i believed its a torsen now im not sure heres some pics:
it has the infamous R stenciled on the casing and here are the numbers found on the internals although nothing shows on real oem once entered:
4061006592
701965
S40 AS
S25 AZ
My first thought was it's a torsen, if you turned the input flange both outputs would turn same direction but if you held one output you could turn the other in the opposite direction. i read torsen diffs act like open diffs until torque is applied.
After opening the rear cover im not so sure as it looks like a clutch type lsd, im confused :?
can anyone tell by looking at the internals???
Motorhole
Post Wed Nov 28, 2012 10:14 am
It looks like a clutch pack to me too from what I can see in your pic. What did the backplate look like?
maxfield
Post Wed Nov 28, 2012 12:16 pm
Looks like it to me mate.
BMW_E30vert
Post Wed Nov 28, 2012 2:55 pm
back plate was a standard z3 backplate the one that looks identical to the e30 ones
HairyScreech
Post Wed Nov 28, 2012 10:26 pm
Funny this should come up, I have just done something similar for a compact track build, was under the impression they were all torsen type but it looks just like yours and i think i can see clutch plates in there if I look deep.
It does however turn opposite if you turn just one flange, had me worried for a while until I opened it up.
BMW_E30vert
Post Thu Nov 29, 2012 4:31 am
i think its a clutch type from that picture motorhole posted, does this mean this is the same as the z3m diff? does anyone have a z3 torsen diff to compare? :?
Motorhole
Post Thu Nov 29, 2012 9:12 am
Was just thinking about the backplate as the Z3M and E30 M3 backplates are different from all the others, with a protruding cluster of cooling fins at the bottom.
Gareth (member on here) might know. Also, DanThe has a torsen diff in his track car iirc, he might have an idea.
Post Thu Nov 29, 2012 9:29 am
BMW_E30vert wrote:i think its a clutch type from that picture motorhole posted, does this mean this is the same as the z3m diff? does anyone have a z3 torsen diff to compare? :?
I have a torsen Z3 diff., and there are several bits of fusilli visible through the apertures in the diff. cage, as in the pic. above comparing the three types. Rear cover is very similar to a normal E30 diff.
HairyScreech
Post Fri Nov 30, 2012 12:26 am
Cover on ours is as per e30, so much so that if you didn't know it was an z3 diff then e30 would be a first guess.
BMW_E30vert
Post Fri Nov 30, 2012 12:50 am
Found some info which explains the different types of diffs found on the z3m BMW's apparently the one i have is rare as it has 40/25 lock :D
not sure how it found its a way into a standard z3' heres the link:
http://www.r3vlimited.com/board/showthread.php?t=224606
HairyScreech
Post Sun Dec 02, 2012 12:28 am
hmmm, interesting.
I wonder if it's an options box ticking thing.
Post Sun Dec 02, 2012 6:44 am
I have one of these tucked away too
That R3V thread is probably the best way to explain it, no/less lock when lift off, not that ive driven with it but a mate has a built LSD in his race car that behaves the same way.
Brian28
Post Sun Dec 02, 2012 8:09 am
Viscous/torsen type are awesome diffs on a race/track car, zero lock when you don't want/need it, variable up to 100% lock when needed. I have a 4.1 on my racer, and a 3.91 (rebuilt by diffmeister Gareth) from my brothers that will be for sale soon.
For sale - E30 320i racer project - sold.
Post Mon Apr 07, 2014 9:33 pm
Motorhole wrote:Was just thinking about the backplate as the Z3M and E30 M3 backplates are different from all the others, with a protruding cluster of cooling fins at the bottom.
E30 M3's do not have that back plate with cooling fins.
Only Z3M's do.
