m52 in! just few bits to finish off:)
daymo69er
FITTED:)
well done ,you need an m40 wiring loom cover on the bulkhead
+ a yard full of scrap turds
daymo69er
i have one just havent got around to it yet:)!! , getting there slowly tho:)
breakermart
do you have any more pics or info of the conversion. doing the same myself. let me know how your finding it mate
Jimbob
What shell is it mate? Get yourself a battery in the boot kit if you can.
daymo69er
ive got a few pictures of it but there crap quality due to havinh a crap phone at the time ill put the battery in boot when got a bit more cash but clutch is slippin so getting a stage one clutch next thats priority:)
daymo69er
breakermart
good stuff!
eko
- Old timer
Are you leaving the ECU where it is now?
Might be best using some washers or similar to raise it up a few mm to avoid damp getting into it.
If you remove the E36 wiring cover you could flip the loom over and mount the ECU under the dash as per original.
