M3 Castor Bushes
poolnoodle
Tue Oct 23, 2012 4:41 am
Hi All,
The chromie needs new castor bushes and I have read all about the benefits of M3 eccentric type. I can get a OEM pair for less that US$50 from Pelican.
My local BMW Autohaus is going to fit them for me - any dramas to expect?
Will they fit ALL e30s?
Will I need a wheel alignment once fitted?
TIA
Neal
mark_i
Tue Oct 23, 2012 5:02 am
Hi Neal
the offset bushes work with all e30... i got them on my touring and 2-door.
both feel so much better in terms of precise steering.
**BANNED**
Tue Oct 23, 2012 6:47 am
Make sure that they line the bush up correctly with it's housing,the aim is to move the base of the wheel out and a little forward.
Yes,have the tracking checked and adjusted as required.
You may also need to adjust the fit of the front plastic underpanel to stop the tyres catching on full lock as well.
Advantages are noticable,I ran two E30's side by side once,one with eccentric front bushes and one with concentric,even 'er indoors noticed that the eccentric fitted car 'steered better'.... :D
Youth is wasted on the young.
poolnoodle
Fri Oct 26, 2012 11:05 am
Thanks guys - sounds like the way to go :cool:
Fri Oct 26, 2012 11:11 am
Only downside is that on full lock the tyre will rub on the inner arch plastic splash guard slightly.
Not sure if it would do the same on a pre facelift
Demlotcrew
Fri Oct 26, 2012 11:56 am
daimlerman wrote:Make sure that they line the bush up correctly with it's housing,the aim is to move the base of the wheel out and a little forward.
They wont move the base out or alter the track width only castor angle.
steve_k
Fri Oct 26, 2012 12:03 pm
Demlot, what would the effect on the handling be if you were to use the m3 eccentric bushes with the offset top mounts??
I only ask as I am looking at using both of these.
OP sorry for the hijack.
Demlotcrew
Fri Oct 26, 2012 12:26 pm
Bushes cause castor change, top mounts cause camber change, it really does depend on what you are trying to achieve, for a track car both will only result in better handling :wink:
Dont forget, the amount of -ve camber thats needed is totally proportional to the roll of the car. What that means is, if you have a boat then no top mount I know off will neutralise the effects.
Andrew
steve_k
Fri Oct 26, 2012 1:01 pm
Well i'm aiming for a cross between a road car (mainly) & a track car.
i'm going back to using coilovers (F & R) in the new year & i'm currently using a 24mm fr ARB & A 18mm r ARB.
I ain't interested in outright topspeed just want a car that handles the best it can.
Demlotcrew
Fri Oct 26, 2012 1:05 pm
I would not advise you run large -ve camber settings on the front, you don't want to loose front end grip on the road (even though underteer is easier to correct than oversteer) during hard braking. Just set the car up for road and enjoy it on track. You cant have both sadly.
Andrew
steve_k
Fri Oct 26, 2012 3:05 pm
No worries Andrew thanks for the advise :)
steve_k
Sat Nov 24, 2012 8:45 pm
Demlotcrew wrote:I would not advise you run large -ve camber settings on the front, you don't want to loose front end grip on the road (even though underteer is easier to correct than oversteer) during hard braking. Just set the car up for road and enjoy it on track. You cant have both sadly.
Andrew
well i took your advise (in a way) & have now got a set of m3 eccentric bushes & also refitted my eibach adjustable top mounts,
at least now when/if i take it to a track day i can set it up for -ve camber for handling & when i've finished i can set the front end back to standard camber for the drive home.
Sat Nov 24, 2012 9:15 pm
Alex wrote:Only downside is that on full lock the tyre will rub on the inner arch plastic splash guard slightly.
The splashguards are adjustable - on max adjustment no rubbing :wink:
poolnoodle
Mon Dec 03, 2012 3:38 am
Having the bushes fitted tomorrow and wondering what is involved here:
The car runs 16x7.5" wheels, lowered on Eibach Pro Kit
**BANNED**
Mon Dec 03, 2012 10:20 am
If you examine the plastic panel's mounts,you will see that they are mounted by those black plastic 10mm nuts onto welded studs.The plastic panels all have slots instead of holes to allow for adjustment...so slacken off and pull 'em about until the wheels clear the panels on full lock.
The tyres rubbing on the plastic bits is not a problem for MoT in the UK,no idea if you lot who walk on your heads will have an issue,though!
poolnoodle
Fri Dec 07, 2012 1:09 am
No MoT inspection around these parts - pay the fee you get to drive it so long as the boys in blue don't catch you :mad:
Hopefully get the car back today so will take a closer look.
HairyScreech
Sun Dec 09, 2012 4:38 pm
Your ride height will have an effect on how much static camber you need as well, as the angle of the lower wishbone is important, it dictates the camber change in roll and bump.
For an e30 around 30-40mm drop from standard height (not mtech) around -1.5 to -2.5 degrees seems to be a good point to aim for on the front for general day to day depravity and some fast work, seems pretty livable for both if you stick around there.
Seems to be true for the e36 compacts as well.
40mm drop with eccentric bushes gives about -2 to -2.5 front camber and a few degrees extra castor, tyre wear is reasonable, grip is reasonable and feedback is excellent.
One thing to remember is track days are not timed races, its far better to have something half a second slower on track that is more fun and easier to drive than something set up for ultimate grip that snatchy and uncomfortable.
poolnoodle
Mon Dec 17, 2012 10:36 pm
M3 bushes now fitted and makes a nice improvement - particular higher speed / sweeping corners. Car feels more planted and steering more responsive.
Have noted that low speed (ie parking, etc) is slightly heavier. Is this normal?
Had no issue with tyres rubbing inner guards.
HairyScreech
Wed Dec 19, 2012 12:20 am
Normal on all 3 accounts, some cars catch some don't, I think its down to splash guard adjustment and e30 vs e36 rack.
