window's not working again!!!
steve_k
Post Sat Nov 24, 2012 7:07 pm
right this is really starting to get on my tits now,
i thought i'd got it sorted the other day after fixing a break in the wire.
but now it's gone again :x i've checked the wiring, no faults there as far as i can see,
i'e read on here a while ago about the "resettable fuse" which some of us often call the "breaker switch". now what i'd like ti know is would/could this be the cause of the fault??
strange thing is there must be power getting to the window switches as they light up when you open the door's or put the headlights on yet when you press then to lower or raie the windows, nothing.
so, could this resettable fuse be at fault or is there something else going wrong??
help me out if you can please folk as it's starting to do my head in now.
T.I.A
BenHar
Post Sat Nov 24, 2012 7:26 pm
Have you worked though this: http://www.e30zone.net/e30zonewiki/inde ... ot_working
(scroll to the bottom.)
Ben
steve_k
Post Sat Nov 24, 2012 7:29 pm
cheer's ben i'll have a read through later & see what happens.
steve_k
Post Tue Nov 27, 2012 9:32 pm
evening folks.
right then, STILL stuck with this problem :x
went through the guide in the wiki & that did naff all, so i'm stuck with this & it's doing my head in now :cry:
so, if any one has any ideas then PLEASE post up here.
thanks.
tylert
Post Tue Nov 27, 2012 9:55 pm
Hey sounds stuiped but i had the same problem, have you checked the wires on your starter motor? as you start your engine if kills power to everything else it could not be recirculating :/
Best way to check find a stright bit of road turn the car off and a few seconds then bump it hope this helps.
HJG-E30
Post Tue Nov 27, 2012 9:58 pm
I'm breaking a 325i and both electric windows are fully working, if you need any parts.
Also I know this may sound obvious, but are you sure the breaker switch is definitely fully depressed?!
steve_k
Post Tue Nov 27, 2012 10:02 pm
tylert wrote:Hey sounds stuiped but i had the same problem, have you checked the wires on your starter motor? as you start your engine if kills power to everything else it could not be recirculating :/
had a look at that earlier (before it pissed it down :roll: ) & it looked to be in place. will have another look tomorrow & see if it is.
@HJG-E30 thanks for the offer dude if i need owt i'll give you a shout.
the "breaker switch" seems to be fully down i'll check in the morning.
read on here that it's a resettable fuse according to mr moooooore.
Post Tue Nov 27, 2012 10:37 pm
Lights in the switches won't light if the breaker is up.
".....the window switches as they light up when you......put the headlights on " Are you sure of this? Switches should light when you open a front door or turn the ignition on. No connection at all with the headlamp circuits.
What happens when you operate one of the window switches? Do the lights in them dim or go out? Any response from the window motor at all?
steve_k
Post Tue Nov 27, 2012 10:51 pm
Brianmoooore wrote:Lights in the switches won't light if the breaker is up.
if i open the dooors then the switches light up, also when i press either switch the light dims but nothing from the window motors.
any idea's??
BenHar
Post Tue Nov 27, 2012 11:03 pm
any idea's??
One answer missing.
Do they light with the doors shut and the ignition on?
Ben
steve_k
Post Tue Nov 27, 2012 11:27 pm
ben, IIRC they do, will have to check in the morning.
BenHar
Post Tue Nov 27, 2012 11:31 pm
Where was the break and how did you fix it?
Ben
steve_k
Post Tue Nov 27, 2012 11:37 pm
Ben
it was just after the breaker switch, used a scotch lock as that was all i had at the time & it seems to have worked for a while but now this :cry:
BenHar
Post Wed Nov 28, 2012 12:58 am
steve_k wrote: used a scotch lock
<spit>
Ben
steve_k
Post Wed Nov 28, 2012 7:07 pm
right then, the switchs do light up with the doors shut & the ignition on,
so, does ANYONE have an idea as to what is going on??
here's a run down.
window switchs light up with ignition off & doors open.
they light up with door's shut & ignition on.
but still no idea as to whats gone wrong :cry:
age
Formerly twist316
Post Wed Nov 28, 2012 7:25 pm
your switches have packed up?
try taking the switch from the sunroof if you have one and see if that works, i've had a few go on me before
steve_k
Post Wed Nov 28, 2012 7:29 pm
age wrote:your switches have packed up?
tried that, still nowt :cry:
steve_k
Post Wed Nov 28, 2012 11:22 pm
BUMP BTTT :(
Post Thu Nov 29, 2012 12:35 am
If the switch lights dim, then power is being drawn by the motors.
I suggest you take off one of the door cards, unplug the motor, connect power directly to the motor from a battery to check that the window will power up and down, and then connect a 12 volt 5W bulb to the motor plug's socket and see what the bulb does when you work the switch.
Any chance that you have dealer fitted rather than factory fitted electric windows?
