m30b35 correct emissions.
After finding out my PO had wound the cO2 screw in all the way I adjusted it and got my car running good.
I want to set the AFM correctly with an exhaust analyzer that my mate is going to lend me for the afternoon so it will pass emissions tests. But I need to know what is the correct level of c02 the m30 should be putting out?
Anyone know or can lend some experience on this?
Bristol_Jer
That's from my Autodata CD
Bristol_Jer
Are the pipes seperate all the way through the system?
Bristol_Jer
Same set up as I have on mine, I didn't realise the pipes were kept seperate inside the boxes, I just assumed they were 2 perforated pipes inside each box so the gases mixed!
Cheers Marc,
I still want to tune up my AFM, it's 1000 times smoother at idle now I wound the screw out but still not perfect. I get bugged by little things which is not great when owning an e30 )
So a healthy cO2 mix at idle should read around 1.3 you say ?
zaust
- Zone day release
yepmcbonio wrote:Cheers Marc,
I still want to tune up my AFM, it's 1000 times smoother at idle now I wound the screw out but still not perfect. I get bugged by little things which is not great when owning an e30 )![]()
- Mikey_Boy
That Avatar made me laugh my bollox off! I am near Tarporley fella - whereabouts are you??mcbonio wrote:Lol, yeah was hotdog sausages being thrown into a womans face.
Where abouts in Cheshire are you Mikey?
mcbonio wrote:Yup, m30 headers going into a 325i exhaust system. No X pipe.!
If its a standard 325i exhaust, I've never cut open a centre box, but the backbox is separated into 3 sections along its length. Both pipes pass through each section in a complicated mess of pipes to keep the noise low, and the gas from each pipe does mix in each section of the box through perforated pipes.Bristol_Jer wrote:Same set up as I have on mine, I didn't realise the pipes were kept seperate inside the boxes, I just assumed they were 2 perforated pipes inside each box so the gases mixed!
My 325i was gas tested with a single probe in one tailpipe and when the MOT place got a new gas tester, a single probe in a large 'cup' type collector that covered both tailpipes. It never failed an emissions test and the results didn't really vary between tests.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- Mikey_Boy
It was a challenge.....!
Horses for courses - one man's meat is anothers poison and all that.
And by fook it was expensive - you are right there... But... It will make the right noise - they do make good power though when well set up.
Sausage face woman - I miss that!
