m3 dash
player6
what do i need to make the oil gauge to work and will all the other gauges work ok in a 325i
scot 328i with 260bhp
Jimbob
An oil temp sensor from the dealers for an e30 m3 which is wired back to the tacho and then you need a t-piece style sump plug or something?
player6
anyone know the part numbers ofr the bits i need and do i need to change the white plug on the front for a 6 pot one
jmc330i
To get the M3 oil temp gauge working you need the E30 M3 Oil temp sensor - 12 61 1 309 193
It just so happens to be the same thread as the M20 sump plug. Fit into your sump as a replacement sump plug and wire it back to the clocks, job done
I would assume that the coding plug needs changing from the 4pot to a 6pot one, but Im hoping someone else can answer that for definite.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Demlotcrew
Changing the plug wont work, you need to change the inpet pulse from 6 to 4 and use the S14 coding plug.
Andrew
Andrew
nadz325i
calibraiton for revs, just purchase this baby http://www.dakotadigital.com/index.cfm/ ... prd127.htm will do the trick
cost up to 40 quid...
player6
why do i need this will it not work i need it to rev up to the red line at 7200
Stevin
U would need to get the Tacho re calibrated... I've been thinking of doing this just for the Oil Temp sensor... and so that it stays stock looking.
Just got a bunch of otherthings to do first.
One thing, think I should run a wire down there cause the dash is coming out soon, to be recovered in leather... just a thought
player6
why do i have to do that
