WHEELS & ADAPTORS
325gill
HI GUYS can i fit 5x120 wheels on e30 325i sport with 16mm adaptors F8J B9J CHEERS?
Rtaylor2208
Most of the guys in the know engineering wise won't recommend the use of adpators, you need to factor in the extra width to make sure you end up with an ET approximately between ET13 and ET25.
Rav on here knows his stuff with wheels and should be able to advise.
