Hi just wanted to know if there was a difference in gear ratios on a 318is gear box to the 318i or is it just the same box?
Thanks Jamie
318is gear box different to 318i gear box? need ratios
Jbrettautos
Kedge
All the info you need - http://www.e30zone.net/e30zonewiki/inde ... in#Gearbox
Jbrettautos
cheers , just need the final drive ratio of the 318is gear box now.
Motorhole
Final drive is the differential, not the gearbox. In a standard 318iS that should be 4.1:1
No front wheel drive talk on here, please!Jbrettautos wrote:cheers , just need the final drive ratio of the 318is gear box now.
