Post
Thu Nov 08, 2012 9:00 am
The 325i is an M20, and the sump gasket will probably be the problem. It maybe somewhat easier than changing the crank seal, but changing the sump gasket on a M20 with the engine installed in a car isn't without its problems.
The oil pump sits deep inside the sump well, and prevents the pan from being slid out once unbolted. There are three ways of dealing with this - you can reach in over the edge of the sump and work blind unbolting the oil pump and drive, you can unbolt the engine mounts, release the radiator top bracket and lift the engine as high as possible, or you can unbolt the engine mounts, suspend the engine where it is, and lower the subframe.
