New E30 (320i) with 325i Engine - Touring
timmzey
Edited for privacy
jmc330i
Looks clean
Two things I'm not keen on are the lower front spoiler and as you say, the wheels. I like the roofbars, never seen those on an E30 before.
What front brakes does it have? You may struggle getting the 15" BBS or 16s over them depending on the size of caliper - that might be the reason those wheels were fitted??
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
timmzey
Edited for privacy
Looking good, you say it runs like a a bag of spanners when cold ? my bet is the blue temp sensor or sensor wiring, they really do run shit when cold when either of the two are fooked, sensors are about £15-£20
timmzey
Edited for privacy
Look just behind the dissy cap, there are two sensors in the thermostat housing, one brown one blue. The brown one give the Temp guage its reading, and the other, A blue one give the engine temp to the ecu, a failed one can give bad running when cold, however if its the wiring which is corroded you will need to replace the wiring, you test the wiring with a multi meter at the ecu end, i'am sure brianmoore will be along with which pins it is
- E30 Zone Meets/Events Team
That's a Jimmy Hill front lip.
Very nice
Are they E36 Roof bars ? I like the front splitter too
timmzey
Edited for privacy
oomz1975
timmzey
Edited for privacy
rips318is
