Slight cut out when on freeway
xavier
Post Sun Nov 04, 2012 10:36 pm
When driving on the freeway at about 100km my 323i seems to cut out for a split second. It then goes back to normal. Any idea where to start looking for the cause? Everything else is running fine.
zaust
Zone day release
Post Sun Nov 04, 2012 11:36 pm
When you say cut out. Engine dropped power or total loss of everything including electric (dme).
M30 Tech 1 Touring on gas.
Post Mon Nov 05, 2012 9:32 am
What does the rev. counter do during these incidents?
gmf_uk
Post Mon Nov 05, 2012 10:39 am
sorry to hijack this thread, i had the same issues after a 3 hour journy south all was going well then on the way home about 2 hours in to the journey my car started missing, spluttering, rev counter seemed to be steady tho, was about -2 outside at this time, once i got home took the car for a drive during the next day all was fine, went out again last night and was missing again, any advice? Cheers
Bristol_Jer
Post Mon Nov 05, 2012 6:06 pm
My 320i did this on it's last journey before the lump got ripped out. It cut out a few times for a split second, accompanied by a small backfire, never bothered finding out what it was though!
xavier
Post Thu Nov 08, 2012 1:46 pm
The revs drop right down, but the radio lights etc stay on
Post Thu Nov 08, 2012 2:37 pm
Could be all manner of things, but most likely a loose electrical connection somewhere.
Check the engine to body earth strap, and all connections to the ignition coil, and the distributor cap, rotor arm, HT leads (measure their resistance; it should be around 6,000 ohms) and spark plugs.
If it persists, try another ignition coil, then DME relay.
redcar
Post Thu Nov 08, 2012 5:59 pm
When was the Dizzy cap and rotor arm last replaced?
Post Thu Nov 08, 2012 6:17 pm
xavier wrote:The revs drop right down, but the radio lights etc stay on
In that case it's an engine electrical fault. DME relay is a possible suspect, and is cheap and easy to change, and after that it could be a crank position sensor,or, more unlikely, the ECU itself.
xavier
Post Wed Nov 14, 2012 1:07 pm
Cap replaced one year ago, but the new rotor arm was not the correct height, so I just cleaned up the old one
Post Wed Nov 14, 2012 6:34 pm
I would take a close look at the centrifugal rev limiter built into the rotor arm - perhaps the spring has stretched over the years. It can be safely removed, since the ECU has its own built-in rev limiter, which gives a far more progressive cut-out.
xavier
Post Sat Nov 24, 2012 9:38 am
I don't think mine has the rev limiter. It is a 1984.
Post Sat Nov 24, 2012 3:17 pm
A 1984 L-Jet car will have a centrifugal rev limiter built into the underside of the rotor arm; pull it off, and if you can see a spring-loaded mechanism then that is it.
It can be safely removed - as mentioned above, there is already one built into the ECU, so it is superfluous!
