seized headlight screws...
mcbonio
Post Thu Nov 01, 2012 11:43 pm
Trying to give my headlights a refurb but I can't get the headlight cluster out as the 3 screws that hold it in won't budge. I've used copious amounts of wd40 and I've even snapped the tip off one of my big screwdrivers.!
Is there a knack to getting them out?
Post Thu Nov 01, 2012 11:45 pm
Try harder with the correct size screwdriver. :D
redcar
Post Thu Nov 01, 2012 11:47 pm
They are quite difficult. I put the correct sized screwdriver on to the screw, and hit it a few times with a hammer. I guess this helped to loosen the self tapper. It came out after that.
I'd recommend getting a screwdriver which you can attach a hex spanner on, so while one pushes the whole screwdriver on to the screw, another person can undo the screw using the spanner.
Have fun! :D
mcbonio
Post Thu Nov 01, 2012 11:48 pm
I'm using the correct size screw driver! :cry: I can't even get one screw out.!
Das_BMW_E30
Post Thu Nov 01, 2012 11:50 pm
Long pencil chisel, on the outside of the head of the screw, tap soundly anti clock wise, it should shift..buy new / replacement screws..
Weetabix :D
mcbonio
Post Thu Nov 01, 2012 11:54 pm
The whole light cluster is seized, the adjusters are seized, screws seized.! I can't get the caps off to change the flasher bulbs either. Everythings fooked.!
I need new lights.
Das_BMW_E30
Post Thu Nov 01, 2012 11:58 pm
I pulled a set out today with Marc, i'm sure they're for sale, PM him..
http://www.e30zone.net/modules.php?name ... ofile&u=73
Post Fri Nov 02, 2012 12:03 am
Want some smoked lamps with ALL adjusters working??? winkeye
mcbonio
Post Fri Nov 02, 2012 12:05 am
Depends on how much they are Rav.! winkeye
Das_BMW_E30
Post Fri Nov 02, 2012 12:06 am
Will get your ass PG9'd....
Post Fri Nov 02, 2012 12:10 am
mcbonio wrote:Depends on how much they are Rav.! winkeye
Same as always mate, £130 posted. :D
Jim320i
E30 Zone News / COTM Team
I've got some of those too... Mine are cheaper though! :twisted:
Post Fri Nov 02, 2012 12:12 am
Oi FOOK OFF and find your own sale! :evil:
Das_BMW_E30
PG9's are free......
mcbonio
Post Fri Nov 02, 2012 12:13 am
Das_BMW_E30 wrote:PG9's are free......
LOL
Das_BMW_E30
Post Fri Nov 02, 2012 12:14 am
At point of issue..cost a bit to put right mind.....
Das_BMW_E30
Post Fri Nov 02, 2012 12:17 am
"don't like the look of your numberplate"...here's a PG9..go get a bus....
Post Fri Nov 02, 2012 12:18 am
PG9 is a car that's "Unroadworthy" :wink:
Das_BMW_E30
Post Fri Nov 02, 2012 12:20 am
Depends on the length of the coppers attitude......
Post Fri Nov 02, 2012 12:26 am
Depends, if he's driving round at night
Das_BMW_E30
Post Fri Nov 02, 2012 12:34 am
Yup, pluck the lights out, an jus go for a daytime MOT, I can see the logic....
mcbonio
Post Fri Nov 02, 2012 12:49 am
130 is a bit more than I wanted to spend Rav, plus I'm not really into "smoked" things if I'm to be honest.!
