m30 HT leads
mcbonio
Any of you M30 boffins know what the HT lead resistance should be for the M30?
leeparkes
Leads should read about 5-6K ohm, lead that goes to the coil should be 1-2K ohm.
mcbonio
Ok so, some findings tonight. Resistance tested the ignition leads just now in my nice warm garage. (m30 doubles as a room heater too)
There is a mixed set of leads on the car, half "Beru" half "Ignition leads" brand. All the Beru leads measure 6k ohms all the "Ignition lead" brand ones measure 8k ohms.
The "Ignition lead" brand on cylinder 5, I couldn't get a bloody reading off, even though the car runs on 5 cylinders without it. It must be working to some degree.
The lead on cylinder 6 is missing a few inches of the rubber sheath near the plug, I suspecting that may be the cause of the ticking I get around cylinder 6. I've seen split HT leads tick before today.
What you guys think of that? New leads?
Can M20 leads be used on an M30?
hows your dizzy cap ?
- E30 Zone Meets/Events Team
M20 leads can be used on the M30, so can the Dizzy caps, same part number iirc.
mcbonio
It looks like the PO has had a go at fixing the running problem as the dizzy rotor and spark plugs all look new.
He's overlooked the leads as they look a bit fooked, all mixed sets with some frayed and split and one not giving a resistance reading.
I'll see if my old mate Pacerpete has a good used set, unless you chaps have a set you want to sell?
I have about 3 good M20 sets of leads, i think all Beru, but i won't be able to get to them 'till Thursday.
mcbonio
PM me with a price Ravo baby.
You want dizzy cap too?
mcbonio
The one on it looks near new. No carbon on the button or terminals at all.
PM'd
