I have just refitted my inlet on my m52 ( m50 inlet)
I'm getting a. Hissing noise from around the fuel pressure regulator when I switch off the engine.
It only last a few seconds but I can't remember hearing it before.
The small hose from the regulator to the inlet is fine.
Can anyone help?[/quote]
Hissing noise
Only place there should be a vacuum after the engine is stopped is in the brake servo, so turn your attention to the servo hose and its one way valve.
Alternatively, it could just be the fuel pressure regulator. They can make some strange noises if the fuel pump is running without the engine.
shedrool83
Does sound like the regulator is making the noise.Is it a problem if it is the regulator?Brianmoooore wrote:Only place there should be a vacuum after the engine is stopped is in the brake servo, so turn your attention to the servo hose and its one way valve.
It sounds like the regulator is releasing pressure .
I doubt if there's anything to worry about, but a pressure gauge connected to the fuel supply line to see what happens after the engine is switched off is the way to check.
shedrool83
redcar
Mine does this. Does it with both m50 inlet and m52 inlet.
After shutting car off, you can hear the icv buzzing and hissing for a few seconds. Then after a few seconds it does one big hiss and a click, then goes silent.
See it as proof you have no air leaks
redcar
Why does it prove that there are no air leaks?
It always sounds to me like its hissing through the manifold, I keep meaning to turn off then open the throttle to see if it still does it
rich318i
mine did is, before i cleaned the IVC. Now after 6 months+ its sweetredcar wrote:Mine does this. Does it with both m50 inlet and m52 inlet.
BATTS91
My m50 does this too no grief from it .
shedrool83
Funny you should say that Dan.DanThe wrote:See it as proof you have no air leaks
I was changing the clutch last week and had to remove the inlet to get to the top bellhousing bolt.
When i had the inlet off i noticed the hose from the icv to the tb boot was split.
I replaced it with a new on when putting back together and thats when i noticed the hissing.
Thanks for the replies lads
