Steering pulling to the left alot
tylert
Post Mon Oct 29, 2012 1:06 pm
Yooo car is pulling to the left alot, had the tracking done still the same :/ any ideas?
Post Mon Oct 29, 2012 1:11 pm
Bent wishbone or steering arm, or mismatched/deflated tyres are the usual cause.
mcbonio
Post Mon Oct 29, 2012 3:15 pm
Uneven tyre pressure is most likely the culprit.!
Post Mon Oct 29, 2012 3:25 pm
Is it pulling to the left while going along a straight road normally, or only under braking?
It is worth jacking the passenger side of the car up and checking to ensure that the nearside front brake isn't binding.
greg124
Post Mon Oct 29, 2012 4:56 pm
Recently developed the same problem on mine. Tracked it down to the strut top mount/bearnings.
Picked the parts up from GSF today.
Of course that doesn't necessarily mean its the same cause on yours - all of the above are possible culptits...
Schadenfreude - the German's haven't got a word for that.
tylert
Post Mon Oct 29, 2012 11:56 pm
does it all the time not just underbraking, brakes are not binding ill try tryes first i guess :p
Post Tue Oct 30, 2012 12:08 pm
Try swapping the fronts over, to see if it makes any difference.
Post Tue Oct 30, 2012 1:15 pm
Checked the rear alignment?
