wiring up a sound system with car battery ?
polsta
Post Mon Oct 29, 2012 2:32 pm
finaly got a missing thing i was after , an 8pin din cable to link my blaupunkt memphis to the blaupunkt amp, took me a while (thanks to bss for pointing out you can use an alpine bus lead)
ive never had the stereo in a car yet, next i ned to buy some speakers, once i get them- is it ok/not ok to just wire the system up on the floor and connect to a car battery, to just check its all ok ? is there anything i should do and dont do etc ?
think im going to go with focal speakers this time round and try them
bab-91
Post Mon Oct 29, 2012 3:04 pm
I had focal's they where very VERYYY good. :cool:
I got the wiring for mine sorted, lets see this lead that eluded us both :mad:
IG - bab91
polsta
Post Mon Oct 29, 2012 3:08 pm
i hear they are good, had alpines,kenwoods, vibe etc
just search alpine m bus lead on ebay, they are the same 8 pin din , £12 it was ,just want to give it a try and see if it all works ok before it comes to the time to put it in the car, bought the amp on ebay a while back but have never tested it
polsta
Post Mon Oct 29, 2012 3:10 pm
diable wrote:Make sure the live is fused.
what size ? you mean just an inline fuse ?
how would i earth it the stereo ? amp ?
polsta
Post Mon Oct 29, 2012 3:19 pm
i want to wire it up as in on my kitchen table , not on/near the car, which i dont have at the moment as its being painted
but ive got an inline fuse cable from an old sub box ,any other way to earth it ?
Post Mon Oct 29, 2012 3:46 pm
Connect the live side (fused) to the live + on a battery and the earth cable to the negative - on the battery.
capnmchl
Post Mon Oct 29, 2012 5:14 pm
My radio in my workshop is just a car stereo with a couple of speakers attached, but instead of a car battery, I used a computer PSU.
If you have an old computer you don't need, steal the power supply out of that. You need to join 2 wires together, but there's loads of pin diagrams on the internet. Then you have a DC electric supply that has perfect 12, 7.5, 5, and 3V sources, and will shut off the moment there's a short circuit.
BATTS91
Post Mon Oct 29, 2012 6:30 pm
capnmchl wrote:My radio in my workshop is just a car stereo with a couple of speakers attached, but instead of a car battery, I used a computer PSU.
This is how i had a car stereo at home too ! Highly reccomend!
polsta
Post Mon Oct 29, 2012 6:41 pm
how exactly do you do it with a psu ? got any wiring images ?
not got one but could probably find one easy enough, save lugging a battery aswell
BATTS91
Post Mon Oct 29, 2012 7:04 pm
Red = +5V, Black = Ground (0V), White = -5V, Yellow = +12V, Blue = -12V, Orange = +3.3V, Purple = +5V Standby
I have a few int shed but im sure ebay would be an easyier option as there cheap , all you will need is a "kettle " lead .
Id also still put in an inline fuse for safety sake
http://www.ebay.co.uk/itm/200807997488? ... 1423.l2649
harry_p
Post Mon Oct 29, 2012 11:10 pm
If you want to stick with the German theme, take a look at rainbow speakers. Crap name, but superb hand made in Germany speakers.
I've just fitted a set of 13cm componants into my e36 ( same size as youd put in the front of an e30 ) and they sound amazing.
cheers,
harry
genozide
Post Tue Oct 30, 2012 6:48 am
On my E30, a pair DLS classic components were installed with 2 way boston acoustics at the rear...powering them were DLS amplifiers with an Alpine 9887 headunit.
and not forgetting vintage Alpine bass 10" woofer in a sealed box...
Sound quality...good audio throw in the front accompanied by non boomy basses...
