Is it condensation/poor rustproofing?
Hot air rising?
Other equivalent aged cars are not so prone.
why do E30 Sunroofs rust?
penton08
The sunroof panel panel rots because the is no paint or protection on the inside, moisture gets trapped between the outer skin and the frame and rots it from the inside out!! It is much the same story with the roof itself, moisture gets in where the sunroof tray is bonded to the roof and festers away unnoticed.
senna
Thank youpenton08 wrote:The sunroof panel panel rots because the is no paint or protection on the inside, moisture gets trapped between the outer skin and the frame and rots it from the inside out!! It is much the same story with the roof itself, moisture gets in where the sunroof tray is bonded to the roof and festers away unnoticed.
My Golf Mk 1 GTi did the same. but I have had loads of 190E's and never seen the sun roof panel rot.
Jozi
You can see here it's only partially painted:
bab-91
The sunroof rusts because EVERYTHING else around it rusts!!!
I apologise... I lost control of my senses.
My e30 and I are going through a rough patch in our relationship
IG - bab91
IG - bab91
senna
Attach some Zinc to it... Sacrificial Protection.....bab-91 wrote:The sunroof rusts because EVERYTHING else around it rusts!!!
snakebrain
I was going to say it rusts because it's attached to an E30, but in the circs I'll keep that to myself.bab-91 wrote:The sunroof rusts because EVERYTHING else around it rusts!!!
Check out the farmer selling his E30 in external ads, that'll cheer you right up!
bab-91
I doubt it, I can show the little surprise's my car had for me
IG - bab91
IG - bab91
