prop shaft DOUGHNUT!
dot
Hi all any advice will be appreciated, my rubber doughnut has split so that the metal inserts are now touching each other this is a new rubber coupling, has anyone elese had this issue? or are you using a different prop shaft coupling for turbo'd lumps??
TPS
I would get that sorted,as soon as possible, before driving the car again, I don't know if the part is different for turbo models.
mark_i
2 points when installing a doughnut, aka guibo
1- check the arrows on the guibo should point to the flange of box and prop
2- when tightening guibo bolts, rotate the nut or bolt that is touching the flange to avoid twisting the rubber
ross2009
nope mines fine up to about 400 bhp so far no issues
dot
I see there must be some other problem I know the doughnut was fitted the correct way I'm not sure how the bolts were tightened,my max bhp is around that mark so can't be the power ripping it up. I think a genuine bmw one is the next step incase the pattern part was faulty or from a dodgy batch
This shows the outcome when one lets go:
BigJoe
ross_jsy
I wouldn't be installing one of those solid or polybushed ones as BMW designed these to take out the vibrations in the drive train, but more importantly to save the gearbox, prop and diff from shock. It's a lot cheaper and easier to replace one of these than other parts of the drive line.
Have seen some big power builds still retain them with no problems so I would recommend replacing it with a genuine BMW one and see how it goes
ross2009
yeah im with ross on this like i said mines puttng out some bhp and mines an old one and its fine
craigieeb
Same here,
the standard one i have on mine is good enough,
as long as its installed properly and the bolts are the correct torque,
then it should last a long time
M50 Turbo!!!
I shall say no more
BigJoe
leeparkes
If its a standard M20 2.5 prop your using why not upgrade to E36 328i prop?
its the same length but has the larger guibo up front.
ross_jsy
Bogjoe, honestly it sounds like you have another issue on hand, possibly alignment. What power is your car making?
