Just change your oil every now and then please!!
maggspower
Turbo Farmer Tractor Driver
Post Sun Oct 21, 2012 10:00 pm
Or this is what will happen :clin: :hammer:
The car in question is a 728i Sport, so a M52B28tu engine, 146 000 miles, its a breaker and I had written the engine off as I could see the tip of this iceberg through the oil filler cap, but on closer inspection under the rocker, its epic. The engine still runs ok but i dont think I'll be selling it on :D
I reckon its done most of its milage on 1 oil change. When I took apart my m20 which had 309 000 miles, FSH to 260 000, and then me servicing afterwards, it was clean as a whistle, the aluminium parts had just gone a golden colour.
So kids change that oil!!!
rich318i
Post Sun Oct 21, 2012 10:11 pm
love to see the sump. oil looks cooked
maggspower
Post Sun Oct 21, 2012 10:19 pm
Well, I'll be looking in there, as the sump, oil pick up, and dipstick ar ok for an e30 m5x conversion.
The_Haywood
Post Sun Oct 21, 2012 10:26 pm
Oh wow thats grim! I remember doing an oil change on an 03plate transit van and i undis the sump and it oozed out like really thick lumpy mess... Must of had the original oil in it. Engine was f**ked
Post Sun Oct 21, 2012 10:38 pm
Bit of flushing oil, perhaps mixed with paraffin, will probably see that alright again.
leeparkes
Post Sun Oct 21, 2012 10:56 pm
Nasty. :eek:
maggspower
Post Sun Oct 21, 2012 10:59 pm
Speedtouch wrote:Bit of flushing oil, perhaps mixed with paraffin, will probably see that alright again.
I'll stick some through it, then you can buy it, I reckon it would liven up one of your moggies :D
Post Sun Oct 21, 2012 11:18 pm
Well, if it still runs OK at 146,000 miles, there can't be that much wrong with it...
Post Sun Oct 21, 2012 11:27 pm
I bet you put Sawdust in that Byron 8O :D
TPS
Post Sun Oct 21, 2012 11:49 pm
Jesus, thats horrendous.
maggspower
No, I save that for the gearboxes and diffs :D
Post Sun Oct 21, 2012 11:50 pm
That looks like its been cooked.
rich318i
Post Mon Oct 22, 2012 12:07 am
lucky if the timing not jumped.
saloon591
Post Mon Oct 22, 2012 8:20 am
A case of the black death by looks of it lol
George
Post Mon Oct 22, 2012 8:26 am
8O 8O 8O
Speedtouch wrote:Well, if it still runs OK at 146,000 miles, there can't be that much wrong with it...
Better you than me!
mani
Post Mon Oct 22, 2012 4:23 pm
woow thats bad lol
maggspower
Post Mon Oct 22, 2012 5:16 pm
Like I said the engine was written off before the car was purchased, there is no way I would put my name to selling that, it looks like somone has taken a dump in the oil filler after a night on the Guiness. Ross?
It will yield enough in parts, plus I need my sleep :D
Its going back together but only so I can move the barge that its in around.
Andyboy
Alpina Colada
Post Mon Oct 22, 2012 6:14 pm
Probably still runs okay...? The bits that matter looks to be perfectly clean. Ford CVH's used to be a LOT worse than that and still work fine.
maggspower
Post Mon Oct 22, 2012 6:40 pm
Andyboy wrote:Probably still runs okay...? The bits that matter looks to be perfectly clean. Ford CVH's used to be a LOT worse than that and still work fine.
Yes still runs ok, It does give off a bit of an aroma as it warms up :D
Ford CVH, fine? :D
Post Mon Oct 22, 2012 6:44 pm
Will go again no problems, just looks like its spent the last 10 years plodding up and down the motorway at a little over idle.
Bit of a head refurb and it will be a perfectly useable alloy engine.
Post Mon Oct 22, 2012 6:45 pm
I saw a CVH powered Mk 3 escort the other day, I could smell the burning oil 3 miles away :D
