Bilstein Shocks help please
smunro90
Hi I'm about to replace my shocks and have chosen to get bilsteins but my problem is I can't find which ones to get. I am lowered on 35-40mm eibachs, so as far as I know I don't need shortened shocks? Which bilsteins are the standard length for example, B4 B6 B8? Thanks guys
smunro90
Also where can I get new bump stops and top mounts from?
B4 Bilsteins, and use E46 cabriolet top mounts from BMW - identical in size and appearance to E30 ones, but of a much stronger construction.
smunro90
Great thanks and its the 51mm I want isn't it? I haves 318is. I had heard of e46 top mounts but also wasn't sure thanks again though.
iS had 51mm struts when it left the factory.
Andyboy
- Alpina Colada
B4's are alright, but Boge Sachs 325i dampers are better - go for Super Touring and they're very good indeed.
