E30 325 Mtech - what to look out for !
Mitchellman
Post Sun Oct 14, 2012 10:44 am
Hi everyone, been looking for the right car for a while. I know what the obvious things to look out for ( Scuttles, Battery tray etc) but what else should I be looking at. I am not a youngster and do quite a bit of my own mechanics but after owning 11 BMW's and having them serviced by garages over the last 25 years I have become a little rusty! I see the Mtech II get a bit of stick on here but I just think they are a great looking car and cant resist anymore!! thanks. Jim in sunny Ramsgate! :o:
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Oct 14, 2012 10:56 am
Ramsgate! Where I went to school!
This article is a good break-down of the problem areas:
http://www.e30zone.net/e30zonewiki/inde ... ing_an_E30
But it also helps to click around the Wiki and check out the Common Problems in each area.
Mitchellman
Post Sun Oct 14, 2012 11:10 am
Thats great thanks. And the Sun is shining on Ramsgate today!!!
hennared323i
Post Sun Oct 14, 2012 11:58 am
I doubt you'll find anything local that isn't a festering turd.
I live near Ash and am constantly on the lookout for decent local (ish) cars and have had very limited success over the last few years.
Welcome to the zone btw
Mitchellman
Post Sun Oct 14, 2012 12:09 pm
make you right, will have to do the traveling but quite willing to do that! and thanks!
e30den
Post Sun Oct 14, 2012 1:44 pm
Mitchellman wrote:make you right, will have to do the traveling but quite willing to do that! and thanks!
You don't see many decent e30's round these parts. i have recently put mine back on the road, and enjoying it :) i'm only down the road in herne bay if you need a hand inspecting a e30 i know them intimately after the last few years of buying breaking a few whilst sorting out my 325
Mitchellman
Post Sun Oct 14, 2012 5:13 pm
Do you know what I really appreciate that and I may take you up on it. Thanks very much. Would like to see your 325!
sunnysr
Post Sun Oct 14, 2012 6:13 pm
have a look up in the rear arch on the fuel filler side up in there they rot in there quite bad and often you cant see until its into the boot .remove the trim in the boot on the right hand side look for holes ,take a torch and have a good look up in the arch ,there is also a plastic tank in there not 100% what it is im suspecting a vapour expansion for the fuel tank im just in the process of removing it all to do some welding as mine had gone there ,behind the kit can hold all sorts of joys (see that thread all have a laugh or what have you (a bit further down in this section)
e30den
Post Mon Oct 15, 2012 7:35 pm
No problem, i am about most weekends, give me a shout 8)
G-Bear
Post Mon Oct 15, 2012 9:15 pm
sunnysr wrote:have a look up in the rear arch on the fuel filler side up in there they rot in there quite bad and often you cant see until its into the boot .remove the trim in the boot on the right hand side look for holes ,take a torch and have a good look up in the arch ,there is also a plastic tank in there not 100% what it is im suspecting a vapour expansion for the fuel tank im just in the process of removing it all to do some welding as mine had gone there ,behind the kit can hold all sorts of joys (see that thread all have a laugh or what have you (a bit further down in this section)
Here's the link, to feast your eyes on..
http://www.e30zone.net/modules.php?name ... c&t=227496
Good luck with the hunt, the tech 2 does seem to get a bit of stick on here, I quite like them.
As a general rule..
a cheap tech 2 = a grot bag..
