NO LIGHT OR INDICATOR( HELP PLEASE)
SMALLTHING
HI ALL JUST STARTED MY CAR AND IVE GOT NO LIGHT OR INDICATOR THE FUSE ARE OK
ANY HELP PLEASE
Grrrmachine
- E30 Zone Wiki / Team Member
#1, turn off your caps lock
#2, No lights at all? Front and back, no brakes or reversing lights either?
#3, Which year and model?
SMALLTHING
HI ive got brakes or reversing lightsit is a b reg
Grrrmachine
If you've got no front or rear lights, then it's going to be the switch. Do your full beams work when you flash them?
And "a b reg" means nothing to me.
- **BANNED**
'83ish...so a very early chromie,much potential for rusty earth,perhaps?Grrrmachine wrote:
SMALLTHING
Grrrmachine full beams work when you flash them? but no indicator but i have 4 way flasher 1985 car
Grrrmachine
Still haven't told us the model.
For a start, swap over the high and low beam relays to see if that gets the headlights working:
http://www.e30zone.net/e30zonewiki/inde ... Box#Relays
But I have a sneaky feeling this will be something simple like a bad earthing point for all the instruments and controls in the cabin. Have you fiddled with any wiring recently, such as fitting a new stereo?
SMALLTHING
Thanks for your time
I will check that out So you think it a earth thing?
Is that right ?
Is that right ?
Grrrmachine
I don't think anything until you tell me what model we're dealing with, and whether or not you've been fiddling with the wiring.
SMALLTHING
E30 b reg 85 I have checked the wires still no indicator
