MegaSquirt
exup
Boost Junkie
Post Fri Dec 09, 2005 8:20 pm
where's MegaSquirt kit from ?
, ie what country ?,
not Aus by any chance ?, if so any one address/ contact number
charlE30
Post Sat Dec 10, 2005 8:19 am
Hi mate, I've been looking into this for my M30 3.5 conversion, I'm 99% sure that they're in the USA.
This is the Megasquirt site http://www.bgsoflex.com/megasquirt.html and has links to the places you can buy it from, hope it helps :thumb:
BMW F31 335d xdrive
Ant
Retired Team Member
Retired Team Member
Post Sat Dec 10, 2005 1:23 pm
Megasquirt is a Bowling and Grippo product from the US.
They designed and manufactured the PCB and casing etc , they are designed to be home built and do require a lot of R+D to get working in their intended applications, there is a lot of tech support through the excellent forums, most common 4,6 and 8 cylinder engines have been run on the MS ecu so I'm sure basemaps can be obtained to get you up and running.
Frank( Exup ) is loking to run a dual fuel setup hence the question I think ?, the short answer is yes no problemo, but it will require a bit of DIY tweaking to enable the dual fuel tables and run each to the specified AFR. Thats the fun part :cool:
exup
Boost Junkie
Post Sat Dec 10, 2005 6:29 pm
Thanks , just doing a bit or R&D,
Yep Ant , want to understand its dual fuel mapping , looking at it for lpg , then turbo then + nos already got NOS kits & controllers ., but thats way off dual fuel + turbo first
thanks
Boots_Walker
Post Sat Dec 10, 2005 9:20 pm
hey exup, i bought my kit from www.glensgarage.com back in 2004 - very happy with the service
have you checked out the forums etc at www.msefi.com?
exup
Boost Junkie
Post Sun Dec 11, 2005 11:27 am
Thanks 4 all the info ,
looks like a big learning curve , but thats all part of the fun ,
i want to use it to run in a dual fuel /lpg mode and do away with a seperate lpg ecu
