Brake warning light
cjdonny
Post Tue Oct 09, 2012 4:24 pm
318 IS none ABS
Brake warning light on the dash comes on now and again,is this just for pad wear with the sensors or anything else?
was on when i got the car in June but since has had all brakes replaced and new sensor on rear but still comes on
any help would be great thanks
jmc330i
Post Tue Oct 09, 2012 4:31 pm
Red light or orange light?
James
'91 325i Sport
'93 318i touring 16v
cjdonny
Post Tue Oct 09, 2012 4:38 pm
its the red one,next to handbrake warning sorry
jmc330i
Post Tue Oct 09, 2012 5:01 pm
My bad, ignore my question. E30s don't have the orange light. Been in my work van all day with the orange brake pad light on :roll:
You say it had a new sensor at the rear, what about the front?
I normally check the light operation by bridging the two pins in the plug for the sensor - I've got an old sensor plug with the wires joined, from when I didn't fit the sensors but needed the light to go out.
If the light goes out with all the plugs bridged, but stays on with the sensors plugged in, you either have a dodgy sensor or connection at the plug.
James
'91 325i Sport
cjdonny
Post Tue Oct 09, 2012 5:05 pm
cheers
will check the sensors as you said
buy a front sensor at the weekend and see if that sorts it
318 IS
jmc330i
Post Tue Oct 09, 2012 5:14 pm
To be honest, if you're not worried about having the sensor, I'd just cut the wires (sensor side of the plug) and join them together - you will then know if the light goes out. Insulate the join well and leave it till you next replace the pads, they normally come with new sensors.
James
'91 325i Sport
Post Tue Oct 09, 2012 6:48 pm
220 ohm resistor. Search function or wiki.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Oct 09, 2012 6:59 pm
cjdonny
Post Wed Oct 10, 2012 4:12 pm
thanks for replys
came on this morning on way to work...hit the dash and it was gone :roll: :wink:
318 IS
