M20 B25 Hard starting when warm/Hot
Andy325i
Sun Oct 07, 2012 11:29 am
What could this be?
It eventually goes after a lot of cranking.
Starts fine when cold
Thinking blue temp sender?
Many thanx
Andy
pnd
Sun Oct 07, 2012 11:47 am
this is a tricky one i have had this problem on several 325's and never solved it despite changing both temp senders.
Sun Oct 07, 2012 12:32 pm
If it was temp. sensor related, it would most likely run poorly when hot, as well as be difficult to start.
More likely to be ignition component related, giving a reduced spark with the low battery voltage while cranking, or be a leaking injector or two.
Does it start easily if the attempt to restart is almost immediately after it has stopped, or does the problem only arise if left for several minutes?
Andy325i
Sun Oct 07, 2012 7:14 pm
Hi Brian, not sure but will give it a try :)
Distributor cap, rotor arm and plugs aren't that old. Well that said, probably about 18 months now but done less than 2000 miles
Andy
Andy325i
Mon Oct 08, 2012 8:14 pm
Right had a chance to look at it today, hardly started when cold, had a look and the Fanbelt and P/S belt are hanging off. Will get new ones ordered and a new set of plugs for good measure
Andy
tha881
Mon Oct 08, 2012 8:35 pm
This used to happen on my car, always fired up first time from cold but sometimes when warm you had to keep cranking it. I found that pumping the pedal a bit as you turn the key would help.
Anyway i changed intake manifolds a few weeks ago and it seems to have cured it. The car has done about 135k but the intake runners had a lot of carbon build up. I can only asume when hot this was running down into the cylinders and fouling the plugs? It has been pretty much perfect since i put the clean one on.
soul4t
Tue Nov 27, 2012 9:46 pm
Andy325i wrote:Hi Brian, not sure but will give it a try :)
Andy
Did you try starting it just after shut off?...Could be residual fuel pressure, I had a similar problem and retrofitted a check valve on the fuel supply line, under the fuel pump cover. Cured mine!
Andy325i
Sun Jun 16, 2013 11:44 am
It's like it if you start it 30 secs after it's been switched off or 15 mins. Slightly annoying lol!
jonny323i
Sun Jun 16, 2013 8:03 pm
I'm sure some had a similar problem and it was poor ht leads
Touring for life
foggy50361
Tue Jun 18, 2013 2:58 pm
I've always thought this was down to the fuel rail absorbing the heat of the engine when shut off causing low pressure, until when cranking the rail pressure is restored then whooa there she goes.
foggy
mine goes first turn when cold, 5-10s or so when warn/hot
