Ok im looking into making an air ride kit for my e30. The one problem im having is finding some shorter 51mm shocks. When i mean short i want to be able to cut the strut towet to fit them.
If not i was going to make a hole new strut and weld it to the hub and add a reinforcing tube.
Bmw e30 51mm Shorter shocks
Jozi
Audi 80 I think had shorter struts
handpaper
MkII inserts are, I believe, 51mm. Used by one company to make shorter e30 coilovers.
christophsbmw
Ok cool i have some mates with mk2 golfs will check it out.handpaper wrote:MkII inserts are, I believe, 51mm. Used by one company to make shorter e30 coilovers.
Kos
sounds like you are going to destroy your suspension if you are going make whole new strut.
best thing to do the is use 45mm struts and use a bilstein instert.
