Rear springs change
jmec
Wed Oct 03, 2012 2:12 pm
How do I change the rear suspension springs on my e30 convertible. It looks to me that a spring compression tool would do the job easier than; as mentioned in my Bentley (publisher no the car!) service manual. Lowering, first the exhaust then the final drive and disconnecting the shock absorber and lifting out the spring fully expanded! Any thoughts please? JJ
Grrrmachine
E30 Zone Wiki / Team Member
Wed Oct 03, 2012 2:27 pm
Rear springs aren't very tall, so you don't have much length to compress them to start with; three spirals, effectively. And that's when trying to compress them even further than the tension they're already under. So you'd need some pretty heavy duty compressors to get them out.
There's a rear suspension guide in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... %28Rear%29
Jos
Wed Oct 03, 2012 2:36 pm
if you want a good workout, use a spring compressor.
If not, follow the Bentley instructions.
Rear springs are very tough to compress, there is also very little room to get them in or out with the spring in place.
'94 e36 tree climber
greg124
Wed Oct 03, 2012 3:40 pm
I think what I did was to put the spring compressors on while the vehicle was on the ground, but tighten up just enough to stop the springs from expanding; then jacked the car up, removed the lower bolt in the shock absorber thus allowing the training arm to drop (watching you don't over-extend the flexible brake lines), giving just about enough space to safely lever out the springs.
It was a couple of years ago, mind...
Schadenfreude - the German's haven't got a word for that.
Andy325i
Wed Oct 03, 2012 3:44 pm
As said, the newer ones will of course be easier to fit as they are shorter :)
steve_k
Wed Oct 03, 2012 4:12 pm
spring compressors on the rear springs??? :wtf:
to remove the rear springs first jack the car up & place on axle stands,
then reove the wheel,
the undo the 19mm bolt on the bottom of the shock & tie it up out of the way,
place a jack/axle stand under the trailing arm.
undo the bolt for the anti roll bar drop link.
slowly let the jack down.
you should know be able to remove the ols spring,
once it's out give the spring pad a clean.
insert the new spring onto the spring pad & slowly raise the jack (make sure the top of the spring is in place).
if it all lines up ok (& it should do) replace the bolt for the drop link.
raise the jack till the bolt hole on the end of the trailing arm lines up with the shock (untied by now)
insert & tighten up the bolt.
replace wheel. remmove axle stand & lower the car back down.
job done.
thats how i did mine a few week's ago.
jmec
Wed Oct 03, 2012 7:31 pm
Great feedback thanks. Next problem; the rear view mirror's dropped off the windscreen. Any good glue out there? Cheers again, JJ :D
e30den
Wed Oct 03, 2012 7:45 pm
jmec wrote:Great feedback thanks. Next problem; the rear view mirror's dropped off the windscreen. Any good glue out there? Cheers again, JJ :D
The rear view mirror is not attached to the windscreen. :)
Wed Oct 03, 2012 7:51 pm
e30den wrote: The rear view mirror is not attached to the windscreen. :)
It is in a ragtop! Get the correct adhesive pads from a motor factors, and make sure both surfaces are absolutely clean.
Using anything other than the correct stuff (especially 'superglue') risks cracking the glass.
Wed Oct 03, 2012 7:56 pm
steve_k wrote:spring compressors on the rear springs??? :wtf:
job done.
THIS, apart from one error. You should not fully tighten the lower damper bolt until the car is back on the ground at normal ride height. If the bolt is tightened at full droop, the bush in the damper eye is permanently twisted.
If the springs won't quite come out when you lower the jack under the hub, raise the jack slightly again and put three or four heavy duty cable ties around the coils of the spring.
jmec
Wed Oct 03, 2012 10:39 pm
Thanks again, JJ
