over heating cab
ash123
this morning my 320i auto started over heating,i was getting water running out of the lower front wing/passenger footwell area i thought it was the heater matrix so i took the 2 pipes off and conected them togetherbut its still the same any one got any ideas
mrLEE30
did you bleed the system after you have cancelled the heater matrix?
what pipies did you connect together?
is it still leaking?
ash123
i conected the 2 pipes going through the bulkhead,it seams to have stoped leaking now and no i have not bleed it beacase i couldnt find a bleed screw on the rad how else can i blead it
SHAZ325iSPORT
you can bleed it by opening the nut on the thermostat housing placed in the middle of the radiator,its got 2 hoses connected to it,i think its a 8ml bolt.
ash123
right ive had another look at it and it seems when the engine is running 2 out of the 3 pipes on the thermostat housing are getting warm the one which goes to the bottom of the radiater remains cold could it be the therostat
