Anyone changed the front wheel bearings?
TheHeap
Post Sat Sep 29, 2012 11:47 am
Morning all, I need to change all the wheel bearings on my 318is but the fronts are fecked so these will be done this weekend.
I have just looked at them on eBay and they look like they are bolted in and not the press in ones I was expecting.
So does anyone have any experience on this?
Terry
jimmyspeed
Post Sat Sep 29, 2012 12:35 pm
the hub is bolted in with a large nut situated under the grease cap
you can knock the hub of but this often leaves the inner race of the bearing in situ, make a notch in the race with angle grinder or hack saw and use a hammer and chisel to remove.
this is what i remember form doing it a few year back , i myself followed a zone guide/guide from the internet - which had pictures and a better description than mine !
TheHeap
Post Sat Sep 29, 2012 4:30 pm
Thank you sir
Post Sat Sep 29, 2012 7:44 pm
These are easy to do, be glad it's not the rears :eek:
TheHeap
Post Sun Sep 30, 2012 11:24 am
Rav they are next :(
Post Sun Sep 30, 2012 11:44 am
I would allow a good day for changing them on a drive.
TheHeap
Post Sun Sep 30, 2012 2:30 pm
It will be at my tyre bay in the dry but on the floor.
Andy325i
Post Sun Sep 30, 2012 3:12 pm
Rears aren't too bad!
Fronts are easy unless the rear ball race gets stuck in place, which it normally does!
Follow the advice above.
Do yourself a favor and buy a decent quality bearing to replace the old one with. Cheap ones often fall apart before you get it fitted!
When fitting the new one be sure to find the right size socket to hit, so that you don't damage the new bearing.
Allow lots of space to work in. I did mine in a lock up garage with about a foot to spare, that was fun!
Andy
TheHeap
Post Sun Sep 30, 2012 6:30 pm
Cheers Andy
