ABS light
herman
ABS light was on, went to a garage with, so they said the gear. They said the rear wheel sensor needed replacing, did this Ԛ£70 for the part. The light still on. Rang the garage back they said it needed re-setting and only a BMW garage could do this. Any ideas how I can reset light. Need a MOT now.
The only "gear" needed to find a dud ABS sensor is a Ԛ£5 multimeter.
ABS light goes off as soon as it's happy, nothing to reset.
Find a new garage.
Find a new garage.
bigkev
sounds great but whats the values of resistance for the sensors please
cheers
cheers
2nd time tonight I've posted this. About 1000 ohms each.
herman
Thanks for the advice
herman
The sensors are ok now light still on, could this mean a new control unit or does it go to OBC
The ABS light come on with the ignition and stay on after the engine starts without the car moving?herman wrote:The sensors are ok now light still on, could this mean a new control unit or does it go to OBC
If you take the plastic cover off the ABS unit (behind LH headlamp), there are a couple of relays there. I've never had a faulty one, but I've read that one of these is the usual culprit.
herman
Replaced the two relays, no joy, must be a wiring problem. Any other ideas.
dasparkybad
there is another relay behind glovebox shoould be a silver one had to change this on my own car because abs light stayed on all the time
herman
Is this behind the glovebox in the car or on the bulkhead, engine bay?
