car died after start up
evilming318ia
so as title say my e30 died 2 mins after start up getting fuel and spark tps good icv good but no start at all .disconnect the maf car start but dies as soon as i reconnect the maf any idea what could cause this issue? need help please
evilming318ia
I guess i wont have any help on here thanks for the viewers keep up mates
TPS
Moved to Technical
BenHar
I don't think E30s have a MAF.
If you want help you need to give more information. eg. what engine have you got?
Ben
Ben
Grrrmachine
- E30 Zone Wiki / Team Member
As BenHar says, E30 engines have AFM, not MAF.
Don't know what engine you have, but if disconnecting the AFM lets it fire, then it's a rich or lean running issue. This is usually caused by an air leak (a split in one of the rubber hoses) or a failing engine coolant sensor known as the Blue Plug.
For more info, check this page:
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
evilming318ia
Problem sOlved it was the fuel pump it works but with no pressure to fuel rail replace it by a new one works great now car is a 88 318ia m40 engine
