Starter motor not engaging
StefanAnghel
Post Sun Sep 23, 2012 8:58 pm
Hello guys,
Need a bit of help,
I've just realised that on my daily 316i auto the starter motor give up and it's spining but not engaging!
Can it be saved or I need a new one?
Any tricks that can be tried?
Post Sun Sep 23, 2012 9:03 pm
Give the starter a tap with the hanle of a hammer, or a long timber peice, try the starter, if it engages it'll need to be reconditioned imo.
Others may have other ideas though.
rich318i
Post Sun Sep 23, 2012 9:08 pm
cam belts gone! worse case if its just spinning over
StefanAnghel
Post Sun Sep 23, 2012 9:22 pm
The engine doesn't move at all
You can just hear the starter spinning
I'll have to take it out to see
Billwill
Post Mon Sep 24, 2012 4:38 pm
Are you sure the thin wires on the solenoid are in the correct places?
The Black/Yellow wire is the starter signal while the Black/Green wire is for the unloader relays.
Leave the Black/Green wire off for a while and try move the Black/Yellow wire to its slot and see if the starter engages. :)
StefanAnghel
Post Mon Sep 24, 2012 6:01 pm
Billwill wrote:Are you sure the thin wires on the solenoid are in the correct places?
I've never touched them...and the car was starting before
I don't have torx keys so I've left it to the local garage
