Quick help with wheel fitment!
jessieparsons1
Post Wed Sep 19, 2012 5:35 pm
Looking at getting some wheels for my car,
Seen a set of Rita grids that I like, they are however 15".
First off how does an e30 cope on 15's? And secondly what will my offsets be like with a 8j wheel et0 and a 7j wheel et 20??
Any help would be appreciated! Thanks in advance!
kam-325i
Post Wed Sep 19, 2012 5:37 pm
15" are standard fittment on some E30's
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Sep 19, 2012 6:26 pm
capnmchl
Post Wed Sep 19, 2012 7:13 pm
They should both be a pretty flush fit. If you're going to lower it you'll probably have to roll your arches but having 15's will work in your favour.
jessieparsons1
Post Wed Sep 19, 2012 7:16 pm
That dosent really help, I need to know what et changes, obviously it comes out from the hub but is that with a negative or a positive? It would be helpfull of a e30 genious would just tell me they will fit with a minimal arch roll!
15" now doesn't see is very normal, it's just my offsets now!
jessieparsons1
Post Wed Sep 19, 2012 7:17 pm
capnmchl wrote:They should both be a pretty flush fit. If you're going to lower it you'll probably have to roll your arches but having 15's will work in your favour.
Just caught that after I posted thanks fella!
capnmchl
Post Wed Sep 19, 2012 10:22 pm
I think so anyway. The rears should be pretty flush. There might be a small bit of poke. I think the fronts might end up poking a bit.
jessieparsons1
Post Thu Sep 20, 2012 12:24 am
any more light on this would be well helpfull!
wounder what the standard 15" e30 wheels dia. are from there i could work out how much the wheels will poke possibly?
Grrrmachine
Post Thu Sep 20, 2012 7:13 am
The standard 15" diameter is 15" :mad: Their width is 7J, as it says in the link I posted yesterday.
jessieparsons1
Post Thu Sep 20, 2012 10:41 pm
And if any one could let me know an et for these that would be appreciated.
Post Thu Sep 20, 2012 10:57 pm
try this iste, all you do is input the size and ET of the wheel and it'll tell you haow far the wheel will stick out.
www.willtheyfit.com
jessieparsons1
Post Fri Sep 21, 2012 12:06 am
That site is wicked! Cheers rav that's going to help! At least I can workOut what impact the et sizes will do! Once again thanks!
