heater problem
thecode
Post Wed Sep 12, 2012 6:46 pm
The heater in my 325 Chromie is throwing a very small amount of heat out on the passenger side blowers and nothing on the drivers side, tried to bleed the system, undone the bleed bolt nothing came out, so changed the the stat and bled the system still no coolant coming out off the bleed hole, therefore still got the same problem, any ideas. :( , getting cold in the mornings.
thecode
Post Wed Sep 12, 2012 10:16 pm
:x
Post Wed Sep 12, 2012 10:18 pm
Are both of the pipes under the bonnet hot?
Does the one from the rear of the head go to the bottom stub on the bulkhead?
Is the heater fan running properly?
thecode
Post Wed Sep 12, 2012 10:41 pm
Brianmoooore wrote:Are both of the pipes under the bonnet hot?
the fan is fine, but the pipe thats conncted to the stat housing is cold, but the other two pipes are hot.
Post Wed Sep 12, 2012 10:45 pm
Question 2?
thecode
Post Wed Sep 12, 2012 11:30 pm
Brianmoooore wrote:Question 2?
will check tomorrow and let u know, cheers
thecode
Post Thu Sep 13, 2012 7:36 am
Both pipes at rear are hot, front ones are hot to now, but still no hot air coming through.
thecode
Post Thu Sep 13, 2012 6:40 pm
:x
Post Thu Sep 13, 2012 8:09 pm
thecode
Post Wed Sep 19, 2012 11:36 am
Yes it does, I have water coming out off the bleed hole as there was a slight blockage which I have cleared, but still all near side pipes are cold therefore still no heat.
Post Wed Sep 19, 2012 1:20 pm
You still haven't answered question 2!
thecode
Post Wed Sep 19, 2012 4:47 pm
Qus 1 No
Qus 2 yes
Qus 3 yes
Hope that's ok
BATTS91
Post Thu Sep 20, 2012 9:10 pm
I seem to be having this problem with m50 , i have come to conclusion my thermostat maybe stuck open , i must sort it out as the ol gal should be back on road end of month and its bloody freezing
Try the ol hot water in a mug trick see if it opens and closes ?
