where is the max skimming point notch on the 731 head?
liam012
Post Fri Dec 09, 2005 2:02 pm
getting the 731 head skimmed this weeekend and i cany for the life of me see the notch that tells you "dont skim past me mr!" i plan on taking a good bit off but want to leave enough meat there for just one last skim should i ever need a head gasket done on it down the line
ta
liamo
disclaimer: i put this in engine swaps and forced induction as i thought people do this to increase power - it could just as easily go into technical though
[/code]
Martinaston
Post Fri Dec 09, 2005 4:52 pm
According to the bentley book the height of the head should be no less than 124.7mm.
New they are 125.1mm.
Not a lot to play with :mad:
There is NO nucleus.
liam012
Post Sun Dec 11, 2005 1:06 pm
thats a shame - usually heads have a sort of guide line notch or indent that u cant skim past....
Jordan
Post Sun Dec 11, 2005 5:53 pm
The marks you are looking for I think are seen well enough in this picture.
This is a 885 head casting, but the marks should be there as well on yours.
http://jordan.lodac.com/Images/December ... 05-005.jpg
They are on the exhaust side, between headbolt holes #1-2 and #6-7
liam012
Post Sun Dec 11, 2005 8:47 pm
cheers
gonna be a close one....
m-dtech
Unapproved Trader caution
Post Mon Dec 12, 2005 2:12 am
if u have the right equipment you should not need a mark...
normaly these heads suffer water jacket damage skimming not normaly neccisary.
