window trim removal
Cloggy Saint
Post Tue Sep 18, 2012 8:31 pm
Can anyone tell me how to remove/replace this piece of trim from my touring? I'm guessing it's a pig of a job. Click picture for bigger image.
**BANNED**
Post Tue Sep 18, 2012 8:50 pm
It is a 'push' fit onto the welded seam between the roof and side of the shell.
I have fitted two to my touring,the first fell off on the A1 heading to my first meet with the touring...the second had added seam sealer to help it stay fixed...it's still there,four years later.
To remove,lever,carefully,from it's lower edge and slide forward to enable you to lift it off the A pillar.
Youth is wasted on the young.
Cloggy Saint
Post Tue Sep 18, 2012 8:56 pm
Cheers DM, just to clarify, it's #4 in the pic, not #6?
**BANNED**
Post Tue Sep 18, 2012 10:11 pm
I've only swapped the bit that runs the length of the roof,from A pillar backwards,I have a sneaky feeling that the bit you are refering to is bonded to the load area window....
Cloggy Saint
Post Tue Sep 18, 2012 10:17 pm
So, back to the pig of a job I first mentioned then? :cry:
mark_i
Post Tue Sep 18, 2012 10:27 pm
Aaaah... not a threadjack, but how to remove item 7 in Cloggy's pic. I have a rusty stain appearing from behind that trim and need to carefully remove it.
TIA
mark_i
Post Wed Sep 19, 2012 10:08 pm
anyone...?
i have tried to lever up the trim with a putty blade but the strip just flexes and bends without coming off the clips...
Cloggy Saint
Post Wed Sep 19, 2012 10:26 pm
And a bump for me too.
mark_i
Post Wed Sep 19, 2012 10:38 pm
oops... the trim item in question is #2 in the diagram... #7 is the rubber seal
spook
League two here we come !!!
Post Wed Sep 19, 2012 10:39 pm
Can you not pull off the plastic gutter trim to get a better look?
spook
Post Wed Sep 19, 2012 10:40 pm
I will look at my nippers Touring and report back :D
Jim320i
E30 Zone News / COTM Team
Post Wed Sep 19, 2012 10:55 pm
From memory, its some very careful prying. Starting from 5, then 6 as im sure it stops it from coming forward, then number 2, that one, pryed upwards, but be carefull as when I did this, I managed to remove one side fine, the other side lifted the clip too much and the back window shattered :cry:
Post Wed Sep 19, 2012 10:59 pm
2# can be removed it's held on with re-useable plastic clips, IIRC it is removed by prising it upwards,
mark_i
Post Wed Sep 19, 2012 11:03 pm
thanks topless... plastic clips? does that mean they get destroyed when removing?
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Sep 20, 2012 7:31 am
#2 has two solid metal locators (one at each end), and five plastic clips just to hold it flush to the window. These clips look like a letter E resting on its back; the trim just drops into it. It's the two end pieces that stop it coming off the car.
If you gently prise the two ends upwards, the trim will just pop off.
mark_i
Post Thu Sep 20, 2012 7:42 am
thats great advice ... i'll let you know how i ger on...Cheers
Cloggy Saint
Post Thu Sep 20, 2012 11:01 am
Number 4?? :cry:
Grrrmachine
Post Thu Sep 20, 2012 11:04 am
To be honest, for my respray I only removed 2, 3 and 7. I couldn't get any of the others off, and the Trim Removal article in the Wiki doesn't cover them either. I have a funny feeling they're bonded on.
Cloggy Saint
Post Thu Sep 20, 2012 5:39 pm
That's a pain, I managed to put a couple of small dents in mine and I really want to replace it.
