m60 clutch
sparkyE30
does anybody know if a m62 pressure plate will bolt onto a solid m60 flywheel?the guy a got it from said use a m62b44 frition plate and an m60b30 pressure plate but if an m62 pressure plate fits then that would be better.any help appreciated.cheerz Mark
FormerMember
M60B40 and M62B44 friction plates have "larger diameter clutch shaft hole" than M60B30 / M62B35 friction plates (6speed vs 5speed 'box). Don't mix them up.
From offset point of view M60 and M62 flywheels are very similar, though haven't ever measured are they exactly the same. The part number @ ETK is different as the M62 flywheel has sensor pick-up points on the flywheel as well.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
sparkyE30
if somebody has an m62b44 pressure plate would they mind measuring from a bolt hole on 1 side directly across to the other and i will measure my flywheel to see if it fits? thanks alot
