Nothing happens when you turn the key.
spbt1
Post Thu Sep 13, 2012 2:36 pm
So recently i have had a problem with the immobiliser cutting power to the fuel pump randomly which i have now cured.
The other problem i'm having is that every now and then and i mean very rarely when i turn the key to crank the engine nothing happens at all i just get ignition lights and thats it, leave it for 5 and try again and it fires over,
Anybody suffered this before or are we thinking it could be another alarm fault.
Thanks in advance
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Sep 13, 2012 2:44 pm
Again sounds like someone's tampered with the wiring. This time you're looking for a black/yellow wire from the ignition key to the starter motor. Have a read:
http://www.e30zone.net/e30zonewiki/inde ... Plug_Start
Billwill
Probably another alarm fault.
Most of these immobilisors cut power to the fuel pump, the injectors and maybe spark and usually stop the starter motor energizing.
I had all these problems at random so pulled the alarm unit out! :?
spbt1
Post Thu Sep 13, 2012 3:02 pm
i am all willing to pull the alarm out but don't want to upset anything in the process,
